We need a general TV Player FAQ! - Contest for contributors :)
Tagging and copying info for the future FAQ. Setup for the Measy RC11 and possibly 12.
Originally posted by gds View Post"Pzebacz im, bo nie wiedzą, co czynią"
Remapping a keyboard
Information to add to the FAQ.
Originally posted by approximatelyprecise View Posthttp://droid-den.com/android-guides/...ware-keyboard/
It works on Finless 1.7a 720p and 1080p.
I was able to correctly map the home button and the multimedia keys on a Measy RC11 airmouse/keyboard.
While doing it I found out that the F11 key is used to manually hide and unhide the status bar and it works really well.
Best
AP
USB devices
Something to add to the FAQ when I do it.
USB devices and ports on TV sticks.
Not all USB ports are "host" ports. This varies by stick model and ROM.
The large full sized USB port is always a Host port. Use this port when plugging in devices especially sound/audio sticks or adapters.
On some devices the USB OTG port is also a host port but NOT always!!!! If you find your device is not working correctly, do not use the OTG port! Use the full sized USB port. The OTG port is for connecting to a PC and sharing the SDcards as removable drives on a PC. It is also used for flashing ROMS. Thus it is a "slave" port not a Host port.
Also on some sticks (MX1, MK808, etc) the rear small micro USB port is power only! It contains no data lines.
Skype not working on some cameras! - FIX
Hey folks here was an interesting find!
Good job Freaktab user: Meh4d2
It appears with some cameras if when you first boot up and setup wifi, if "Automatic Backup" is turned on your first Skype call will work but later calls will fail. Only a Factory Reset seemed to fix it.
Also even when you first setup your device and turn OFF Automatic Backup, then when you go to sign into Google, the last step asks you if you want to keep your device backed up to Google. If you say yes to this, automatic backup is turned on again. So you need to make sure on the last step of sign up with Google you uncheck this option.
See this post for information and how this person found the fix
Re: We need a general TV Player FAQ! - Contest for contributors
Originally posted by neomode View PostSee it as Pool for how's on TV Player.
When we got Time we Transfer it in a Wiki.
Neomode FreakTab.com Developer
Sent from my MOMO11 四核 using Tapatalk 2
Hi Tatubias, thanks for posting all this info. But the idea of the FAQ if for "general" things that relate to ALL TV stick devices or at least many of them. e.g. like power supply issues, or ROM flashing issues related TO PCs, you know stuff that is more generic.
Some of what you posted really belongs in a forum like the CX-01 stuff. It is GREAT information but should probably go in a CX-01 information post rather than a general FAQ for TV sticks.
Makes sense what we are looking for here?
Thanks,
Tell you what, this information is very valuable you have posted!
If you would make a new post for UHost1 and the CX-01 in the "other TV players" area, I can move these posts for you. That way you can edit them as needed since your the poster.
Thanks,
Originally posted by Finless View PostTell you what, this information is very valuable you have posted!
Thanks,
also there are some clones that makes wifi not be compatible with this rom.
Please move them were it should bethanx.
Tatubias, thats for posting all that info! I moved it to specifi CX-01 and Uhost1 threads for you.
That is good info for thse devices! Thanks!
Again for FAQ, we want to stay generic or "common" information for devices. Specific device info should go in it's own thread.
Make sense?
Thanks,
P.S. I will keep you in the contest though for the posts you made!
Originally posted by Finless View PostTatubias, thats for posting all that info! I moved it to specifi CX-01 and Uhost1 threads for you.
Make sense?
Thanks,
Bobi did also added some info regarding the himedia q5 device. here were it should be
also i have some other articles regarding the himedia q4 (dongle mediaplayer) device if you are interested i can post the also in the android tv sectio too.
Approximately how many times should I have to read this stuff before it sinks in? I went to wiki and read what a rom was and what it meant to flash but most of this stuff is still way over my head. The first time I heard of a "finless rom" I wondered why they removed the fins. Some of its starting to make sense now but I would still like to study a few more tutorials before I try my first flash.
There are currently 2577 users online. 0 members and 2577 guests.
