BRICKED MK808 HELP!!!
tried to flash but pc not recognising my mk808. i have 2 units .one flashes fine. no blue light when plugged in. just doest work. i dont know what to do. it was working fine for 2 days then the screen got stuck so i unplugged it . now it wont turn on or let me flash .any help?Tags: None
Originally posted by robs2002 View PostTry this, i worked for me. You need to remove the heat sink and then re-attach it, but it solve the problems I was having with my unit.
http://www.freaktab.com/showthread.p...D-on-the-MK808
How does the PC recognize it? What shows up in device manager? It should be the same device as your other MK808 when it connects and is in flash mode! If not then somehting hardware wise maybe wrong with it.
In fact I just got a Measy U2C and it wont flash either. It is dead basically. BLue LED comes on but PC wont see it at all.
Originally posted by Finless View PostHow does the PC recognize it? What shows up in device manager? It should be the same device as your other MK808 when it connects and is in flash mode! If not then somehting hardware wise maybe wrong with it.
Originally posted by swiftmuvmentz View Postthanks for the quick reply bob. its weird this is the 20th mk808 unit I'm flashing and its the only one that isnt detected by the pc using the pin flash mode so i tried shorting 8 and 9 pin and got my pc to ask to connect . when i click ok nothing happens , rk android not found.. it doesnt show up in device manager either. it only asked to connect to windows and i accept but nothing happens. tried over 40 times. i just need to be detected. plz help bob. i cant let her die!. since then no luck getting it turned on or flashed or even detected by rkandroid pllzzzz help thanks a billion.
I think it is dead my friend. As I said my Measy does the same thing!
There are currently 2962 users online. 0 members and 2962 guests.
