Startup loop...how to break it
    I have a friends Cube U30GT h
    it is stuck at the tablet maker logo after powerup...
    here is the screenshot of the firmware version...
    I have been able to get it into a firmware flash mode..on the tablet itself
    ie mode that enables cache wipe ...firmware from sd card
    and you use the vol + and - to select item
    and power button to ...'enter' selection
    it is still using the original charger...I was thinking of getting a new charger
    one of better quality..and charging the tablet and see if that helps?
    also maybe upgrading the firmware maybe best way to get it out
    of being stuck at boot-up?
    Any suggestions?? TIA
    PS No I didnt cause this issue...my friend asked for help to try and fix it
    Re: Startup loop...how to break it
    You are in recovery if you have those options. In bootloader/flash mode the screen will be black.
    To get to boot loader, with the tab connected to the PC but not the power supply:
    press power for 10 seconds
    Press and hold Vol +
    Press power for 4 seconds
    Release Vol +
    The screen should be black but the PC should detect it. You may need to install drivers.
    I include drivers in my ROM kits.
    900Supersport
    freaktab developer
      Release Vol +
      So youre saying the only way to get the Cube out of this stuck at bootup..loop
      is to load a new firmware...??
      I assume your kit uses the ROM flash tool?
        The kit includes the flashtool.
        It may be worth exploring the option in recovery, you have nothing to lose.
        900Supersport
        freaktab developer
          So not having owned a tablet before...but reading from what goes on here...
          I assume if I use the recovery mode I could reload the original Firmware
          by downloading it
          and putting it on an SD card ..and loading it via recovery mode
          and if I use recovery mode where do I get the original firmware from??
          (as I cant get into the tablet and it wasnt backed up!!)
          and then later...still install your modified / updated firmware
          which would from what I read ...will
          >>Root the tablet
          >>get rid of the chinese apps
          >>and update the firmware
          which one is the best at the moment? its difficult to tell
          ie do you have a thread link??
          Does yours include a CWM?
          or do you always have to use the flash tool?
            by downloading it
            >>Root the tablet
            CWM is included see http://www.freaktab.com/showthread.p...ll=1#post45418
            900Supersport
            freaktab developer
              Thanks for the link...
                I cant believe it...I am touching a big block of wood for good luck
                but I think I may have been able to
                get the seemingly lifeless Cube into flash mode!! yes!
                install the necessary x86 drivers for Windows 7 to recognise the RK30 device
                get the Flash tool to say..."Found RKAndroid Loader Rock USB"
                then have the flash tool.... Erase the NAND ..worked fine(ie did count up)
                then Flash ROM ...
                it looked liked it had failed ie an error message came up...and my heart sank!
                but then I plugged in power
                and unplugged the USB cable and it rebooted
                and it came up with CWM version 6.0 xx....I then said reboot
                and now when I can finally get it working with my router
                I have taken a screen shot ...showing firmware version 1.11!
                I want to send it to this forum..
                First I need to confirm some details????
                There doesnt seem to be any apps showing under Settings??
                Have I not done the upgrade correctly?
                How can I see if it has done the 2gb app space?
                its showing English(UK) under language..and keyboard
                (which is what you say in the firmware details???)..so that seems to be correct??
                  This sounds promising. Did you have a notification that the sdcard is corrupted, just press it and select repair format and you should be good.
                  Here's a screenshot of my storage settings to give you an idea.
                  900Supersport
                  freaktab developer
                    [ATTACH]1710[/ATTACH]
                    Yes I was wondering about that message...as I didnt have an SD card in the tablet
                    I assume it doesnt refer to an external sd card then ??
                    I have just answered the sd card notification...and allowed it to repair format?
                      Sorry I am such a dummy! duh
                      and not having a tablet of my own(just a smart phone)
                      I forgot the front screen doesnt show the apps (unless you add them yourself!)
                        Sounds like you now have a working table. ;-)
                        We all make mistakes, most are not brave enough to admit them.
                        900Supersport
                        freaktab developer
                          and that in settings ..under apps...it shows downloaded ones !
                          and not pre-installed apps..ie ones included in Gapps
                          Duh!!
                            Top right of the screen is an icon, press it to go to the app tray.
                            900Supersport
                            freaktab developer
                              Here are is a screen shot of my Memory area..under settings
                              sorry storage area...under Settings..and its showing Available 1.82GB out of 1.97GB Total
                              it appears it worked?
