Startup loop...how to break it
Re: Startup loop...how to break it
The cat is one of the Chinese apps I forgot to remove. Superuser is part of the root process. It manages which apps you allow to have root access. Reboot can be used to reboot to boot loader (for flashing), recovery. Firs time you use it a dialog should appear asking for authorisation for root access., this is superuser doing it's stuff.
Enjoy the ROM.900Supersport
freaktab developer
Originally posted by 900supersport View PostThe cat is one of the Chinese apps I forgot to remove. Superuser is part of the root process. It manages which apps you allow to have root access. Reboot can be used to reboot to boot loader (for flashing), recovery. Firs time you use it a dialog should appear asking for authorisation for root access., this is superuser doing it's stuff.
Enjoy the ROM.
for the info on these...I assume I can find out more info on Superuser and Reboot elsewhere
>>and...to remove the chinese app..
I would need to activate Superuser(ie to gain adminstrator rights)???
The reboot app is by Petrus from this site. Just press it to explore.
No activation required of superuser. just use the tab and anything that requires root will request it via superuser. From the dialogue you can either allow or dissallow
To remove that app first install esfileexplorer from google play. start esfileexplorer and go to settings scroll down to the root options and check them all. You should now be able browse to /system/app and track down the app you want to remove, long press it and select delete from the menu.900Supersport
freaktab developer
Originally posted by 900supersport View PostThe reboot app is by Petrus from this site. Just press it to explore.
especially how to remove the Chinese orphan app
There are currently 2409 users online. 0 members and 2409 guests.
