not certain on this device but on most android devices there is an icon on the desktop (normally six small squares in a 3x2 arrangement). press this to get to the app tray.
Icon on the desktop? I think you are talking about the app menu. I am not talking about it my friend..I am talking about this: When i am inside an app (eg es file explorer, see my pic above), There is always an other menu (inside the app) when you can access it by pressing a button on the android phone. I haven't find a way to enter this menu ( i dont see any button). Is there a way i can do it?
I don't have an mk 808 so don't think a screenshot will help.
is your mk808 rooted? if so from esfileexplorer goto settings and check the root settings, you should then be able to use the back button to move up in the file heirachy beyond sdcard.
Ok I don't read Greek but explore the menu options at the bottom of the screen, the wheel shaped on is the one you want then scroll through the list looking for root
The pic you i uploaded is not from my mk808 .. it is from my Galaxy S3 mobile.
I can access those settings from my mobile but NOT FROM MY ANDROID BOX. See the pic again:
It is a clear site sorry if it looks like a threat. Check out my second foto..Any ideas how to enter the settings menu of the es file explorer (on my mk808)?Any help would be appreciated
on the MK808 at the top right you have the six dots 3 on top of three that takes you to your apps...just as the 6 dots in the top right are very "discrete" and not noticeable to new users...that said once an app is opened some where in the bottom menu bar of the MK808 will be 3 dots (up and down) almost hidden in between some of the icons. That will be your in app menu. Its very hard to see if your not on a larger tv ... be patient and look very close once you find it it will stand out like a sore thumb. I have noticed on certain apps that the 3 dots appear in the top left or top right of the screen as well. Hope this helps...
confirmed, the 3 dots for in app menu show up in the bottom menu bar on the bottom of the screen between the return button and the volume button for me when I open the ES file explorer using the AWESOME finless 1.6 on an MK808
In mk808 you can access settings in ES file explorer by hitting three little dots in bottom menu bar . These (in other apps aswell) mean that there are aditional settings available.
