Overclock total FAIL!
    need pls help, because I OC my ug802 RK3066 A9 1,6 GHz + 4 GPU MALI with this kernel_1080_CPU1608_GPU500_RAM1332_OC from 2dark4u and now my ug won't start. How could I reset the settings (like pc bios battery?)?
    Always when I try to start the monitor he's black say and "try to connect" then it lost connection and try to connect again and again.
    Greets
    push
    push
      hi look for ug802 recovery
      I help with 4GD663269M466950W
      And you ????
      My devices:
      Tronsmart T428 real 3188 with Finless A928 and D33 Kernel at 720p
      Tronsmart Prometheus won on CNX just now....
        Thx 4 info i'll try!
          won't work
          It won't work the display is still black and nothing happend. Is there any onboard reset button or something else?
            You have to unbrick ug802 by shortening 8,9 pins on the flash rom. It is pretty much like you put a mk808 to mask flash mode. Then you can put the ug802 to recover mode again and flash other working kernels. Need pics? Let me know. Good luck!
              would be nice
              pics and a easy instruction would be nice for me.
              Thx a lot 4 helping!
                you mean this 2 pins? I tried to shortening it with a screwdriver but nothing happend.
                  Re: Overclock total FAIL!
                  no
                  I am talking about 8 and 9 pin on nanad.
                  Sent from my Nexus 7 using Tapatalk HD
                    see red line
                      XIEXIE DOZE
                      Thx man it works, sry I'd watch a russian video before where he tried with this pings to shortening the board
                      great thx
                        Another question!
                        I have flashed the nand 2 times because it always stucking when i updaload 2dark4u and now it stucking again but this time i can't shortening it. Do u have a solution?
                        greets
