About Powersupplies !
    Thanks for the reply. Will go ahead and try tonight since I have the assurance from you.
      Re: About Powersupplies !
      0.1volt higher doesn't matter.
      Take car's computers for example. They are built to run at 12v. But the alternator often produce 14v and it doesnt affect the system. As ling as you stay close to the specs, you will be fine
      I run my device with a lab power supply that can provide a max of 5amp. And its set to 5.1v.
      I also have a 5v laptop fan that is plugged to the same p.s. to help keep the mk808 cold.
      Envoyé depuis mon CJ ThL avec Tapatalk
        Originally posted by masbass View Post
        Yeah, I know, I just took it up a notch from the one posted above as I need to power MK808, USB hub, external USB 2.5" HD, USB webcam, bluetooth remote, USB ethernet dongle, CPU fan intalled on the mk808 chip.
        For AC to DC, something like this would be needed:
        http://www.****.co.uk/itm/25W-AC-90-...item51a8a57366
        or
        http://www.****.co.uk/itm/AC-110V-22...item5d3718d2e3
        Very thing connected! Have a photo?
        The cooler part is interesting, as it was?
        MhagnumDw
          Hello,
          I'd like a follow up from kidaquarius & djangokim's feedback regarding the usage of the iPad adapter. Is everything still running solid? I'm interesting in purchasing a a1357 model.
          Thanks in advance for the feedback!
            atx supply
            I watched a couple utoob vids abt converting an ATX power supply for use as a benchtop supply...
            which is just about what we are doing here.
            Old PCs are frequently tossed, and I've got a small pile of them...
            Fan operational, or not, there should be a place for it down in the cabinet, somewhere.
            ... and, as Leolas has said, an extended power cable, wrapped through a toroid ring should stifle any RF radiating from the cable.
            When I get one past the smoke test I'll post results here...
            rc
              It works good.
              Originally posted by JPZ View Post
              Hello,
              Yes, my stick still works without problem.
              I reboot my stick two weeks ago and no single problem since than.
              Also, I believe firmware is very important part of stability. I'm using Finless 1.7C with 2dark4you 720P kernel.
                Thanks much djangokim, I just ordered one from ****. Lets see if I get owned by the seller with a fake unit. Also bought one of those USB to MicroUSB with a ferrite core.
                  charger
                  I have a generic charger I got off Amazon that works great and was cheap. Have been using it for months now with no problems at all.
                    Noob Alert
                    Hi Guys,
                    Just joined this great, informative forum, learning lots about mini tv. I would also like a better power supply and could use some expert advice in choosing the right one for my MK808B.
                    I've found thispower supply on Amazon UK, It looks good to me but, would it do the job of powering a usb hub and the MK808B?
                    Is the spec ok and does anyone already have one?
                    Many thanks
                    Stroggy
                      Ok, just posting this here for anyone who is interested. I purchased a PNY Black 3.1 Amp Dual USB Wall Charger P-P-AC-UF-K01-EF from newegg and I got the adapter on Friday along with a Startech usb y cable.
                      I've used this usb cable that you can swap out the ends on from walmart that I had laying around to do some testing on each port separately since one port is a 2.1 Amp port and the other is a 1.0 Amp port, then tested with the y cable. I didn't hack up my new y cable since it's the cable I'm going to be using so I modified the walmart cable to connect it to the meter and then to a small usb hub that connects to the y cable.
                      Here are my results:
                      Finless 1.7c and 720p kernel:
                      2.1 Amp port: 1.4 Amps & 2.0 Amps
                      1.0 Amp port: 1.0 Amps (Unstable)
                      Both ports: 1.4 & 2.1, 1.8 Amps & 2.3 Amps
                      Finless 1.7c and 2dark4u's 1.4 mk808 720p kernel with GPU at 433 MHz:
                      2.1 Amp port: 1.4 Amps & 2.2 Amps
                      1.0 Amp port: 1.0 Amps (Highly unstable)
                      Both ports: 1.4 & 2.2, 1.8 Amps & 2.6 Amps
                      The power supply is a true 2.1 Amp + 1.0 Amp power supply with a total output of 3.1 Amps according to the markings on it but I didn't get that high on my tests so I might have some room to grow if it can actually handle the 3.1 Amp claim on the power supply and it's packaging.
                      The results might look strange but I'll explain.
                      Devices plugged into the MK808 while testing:
                      1GB transflash card
                      Hdmi cable
                      Receiver for a Lenovo Multimedia Remote with Keyboard N5901 plugged into the ubs A port
                      The first reading was done after first letting the MK808 boot up and sit for 5 minutes to let things settle down while the second reading was done while running the epic citadel benchmark. Governor was left at default for each test.
                      There are two sets of readings for the tests using both ports since the second set of readings were taken while a usb 2 portable laptop external hard drive was plugged in using the OTG cable. So far the readings have been pretty stable since the power along the usb cable didn't show much variance during my testing, roughly a .1 Amp difference at times.
                      On a side note, each test was done 3 times and then the highest reading was recorded for each time and averaged, which really wasn't much of an average considering the variance in output and I did have a power conditioner plugged into the wall outlet then this adapter plugged into the power conditioner to get cleaner results. The only reason I had this in place is because the original adapter that came with my MK808 turned out to be very poorly designed, like most that are packaged with them I guess. The variances on the original were more in the .6 Amp range after a few days of use, putting the power conditioner in place took it down to .2 Amp for a couple of days but recently it's been back in the .6 Amp range so that one is going in the trash.
                      I'm at work right now and plan on doing some readings without the power conditioner when I get home along with some tests while streaming hd video to the MK808 as well as playing it off of the connected external drive. Those tests will probably give a more varied result on the read outs without the power conditioner. I'll post them when I get a chance.
                      Edit: Ok, I didn't have as much time last night as I had hoped so no readings while watching videos but I did take the power conditioner out of the loop and I'm still getting about a .1 to .11 Amp variance even on the citadel benchmark using both ports and the y cable. To me that's not enough to warrant adding a whole other set of readings to what I've already done since it hasn't changed much. It also made me realize how poorly made the stock power adapters really are with these things.
                      MK808
                      Finless 1.7c
                      2Dark4U 1.4 kernel
                      Lenovo N5901 wireless keyboard+trackball combo - currently looking for suitable replacement
                        Is power supply for mk808b from geekbuying ok?
                        If not pls link for one ok with eu plug.
                          hi all im new here. thanks for this great community
                          yaba
                          i need this info too plz
                          thanks in advance
                            Its the typical Shenzhen special. If you get one marked "2A" its marginally OK. (It actually delivers somewhat less)
                              5V 3A all power for all yoiu need.
                              Get one of this
                              $9.99
                              I help with 4GD663269M466950W
                              And you ????
                              My devices:
                              Tronsmart T428 real 3188 with Finless A928 and D33 Kernel at 720p
                              Tronsmart Prometheus won on CNX just now....
                                Thats not always true.
                                Got a replacement from seller after original stock psu 5v 2a died.
                                measured with multimeter it gives 5.25V 3.75A although supposed to be 5v 2a.
                                so can only say sometimes it all depends on luck!?
