.gif)
My new MK809ii runs very bad. After searching the web, I found all things in this forum that makes me happy.
With Stock-Rom the Stick runs bad. Now I'm lucky with:
- Finless Rom 1.5 (1.6 and 1.7 are for other Sticks; if you install them you can't use wifi and bluetooth)
If you want to install it, push a needle in the very little hole at the side and find the button (very tricky, feel the klick) and install it like described in the readme.txt that is included in the rom-download. - Change the dpi-density. Many tools doesn't work. I used the Rom Toolbox Pro and changed the dpi to the value 240.
- To use the Stick I bought this keyboard from Amazon (25€). Many keys i could programm with the "External Keyboard Helper"-app. If you want you can programm apps to keys; for example "function+F"=freaktab.com or "control+r" for a radio-app and many more
- This 32GB SD-Card works fine and fast
- I use a powered USB3.0-Hub and connected 3 HDD-Drives and the keyboard/mouse-combination and it works fine
- I found many bugs in the launcher-app that comes with finless. I'm using the ADW-Launcher Ex and it works great for me!
I put this Thread here, because the MK809ii seems to be a clone of the imito MX.
In my opinion an airmouse seems to be cool, but it's not funny to use it with the stick. Such keyboards with mini-pads are too small for use with Full-HD-Android.
