If anyone have question just ask
Video:
Youtube https://www.youtube.com/watch?v=MWr-...ature=youtu.be
My website:
---Download---
Use Chrome to download
MK808:
http://adf.ly/JrjNd V2.1.2 720p
http://adf.ly/JrjVq V2.1.2 1080P
MK808B:
http://adf.ly/Jrk3N V2.1.2 720p
http://adf.ly/JrkBs V2.1.2 1080P
changelog:
V2.1.2
-libstagefright.so (new, for better xbmc and other players compatibility)
-setup wizard at startup
-apps updated
-youtube for gtv
-wallbase (tons of nice wallpapers)
-blackmart (unofficial market)
V2.1.1
-rooted
-2dar4u kernel (MK808 only)
-eHomeMediaCenter added
-build.prop changes
-changed defaul wallpaper
V2.1.0
-based on 17/01/2013 Minix Neo X5 firmware
-disabled bluetooth from settings (mk808)
V2.0.0
-LCD Density 240 (1080p)
-added Advanced Task Killer
-added Android Tuner
-added GO Launcher HD for Pad
-minor fixs
-xpad.ko (play yours favorite games with xbox360 controler or any other)
-build.prop tweaks (wi-fi, ui, and other tweaks)
-cifs manager (mount yours shares as they are internall hdd)
-es explorer (manage your files with best file manager, auto apk install)
-youtube (with fullscreen)
-deleted useless aps
-kzis 1.51ghz karnel (best karnel for mk808 ever made)
-app space 2gb
-minix bootanimation
install:
-unpack arhive (anywhere)
-start RKBatchTool.exe
-put mk808 into flash mode (pres hiden buton and conect mk808 to pc, use usb otg port)
-instal proper drivers when windows ask (drivers are in \Rockchip_Batch_Tool_v1.5\Rockchip_Batch_Tool_v1.5 \RockusbDriver)
-when you wil see number 1 in green box selec "..." button in right top corner of RKBatchTool
-navigate to MK808 Hybryd FW V2.1.2 .img
-pres restore button in RKBatchTool
after instal:
thats the things to do aftrer yoy install your rom o mk808.
-first bootup will be slower then the next one (android is setting ui)
-after boot wait about 3-5 minutes and reboot the device
-in Android Tuner
-in android tuner go to cpu an set governor from interactive to performance (optional)
-press onboot
-go to android settings>screan>scale> and slide it to the end
-next go to settings>developer options:
1. check usb debuging
2. check stay awake
3. change all animations to 0.5x
-in advance task killer
-in advance task killer go to settings:
1. check startup kill
2. select startup delay and set it to 20-30s
Also if anyone want the older youtube version with fullscreen heare is the apk http://www.multiupload.nl/DIV93QNXB5
If you installed XBMC for better compatybilit download this file http://adf.ly/K3xHR
Using es file manager (show hiden files must be checked in es settings) put it in
/sdcard/android/data/org.xbmc.xbmc/files/.xbmc/userdata/
Also is recomended to install lates ver. "hwaccel" from http://mirrors.xbmc.org/test-builds/android/
Thanks to:
-2dark4u
-finless bob
-kizs
-minix
