cwm recovery zip for the new libstagefright.so
    I made a cwm flashabe zip to update to the new version. Simply download the zip, copy it your sdcard or external_sd and flash it with cwm recovery.
    I tested it and works fine for me, but i suggest to make a backup of your actual rom in external_sd before you flash anything. So if something go wrong you can recover your actual ROM easy.
    I hope it helps.
    ADVICE: ONLY FOR RK3066 DEVICES.
    Waiting for more reports.
    Like Bob said, we add the new mali libs in /system/lib/egl and all stagefright stuff in a new zip.
    New roms by Finless will add this new feature, so no need to install this patch.
    Pls make a nandroid backup before install it. Thanks.
    I had to remade the zip cause I use the old libstagefrigh.so lib.
    This new zip works in mk808 and mk808b.
    In UG007 reports bootloop by opengj1971
    The one i did before named ug802... Was wrong, I used the old lib. This one must work.
    My devices:
    Gearbest.com)
    Thanks Leolas!
      Hi guys,
      Just to share my experience with the zip update from sd for libstagefright.so.
      I have a clone of UG802 with finless 1.7 rom and finless cwm recovery. After flashing the zip file with updated libstagefright.so the device reported - update successful but after reboot it got stuck on bootscreen. Had to make the whole process with shortening the pins and reinstalling recovery ug802 recovery rom and now I am back to 1.7 finless.
      Not sure I want try to make the update again though.
      Just sharing my case with others. Not saying its generally not working
      Thanks again to bob and leolas for their efforts to make the most out of this stick.
      There is no sp00n ...
        Originally posted by sp00n View Post
        Hi guys,
        thanks a lot for your report, some people talk about issues replacing the lib manually, issues like boot-loop or boot stuck. I don't know why is this. But if you replaces the lib manually, i think that it will the same, and result must be the same.
        My devices:
        Gearbest.com)
          On Ug802 whith 1.7 same problem dont boot after uptade manual or with your patch
            Thanks a lot for your report too. Don´t know why, but seems that ug802 and their clones don't accept the new lib.
            http://www.freaktab.com/showthread.php?3986-New-libstagefright-so-causes-problems-on-MK802III-UG802
            My devices:
            Gearbest.com)
              My bet is because ug802 uses an older version of Mali EGL drivers.
              This might be fixable by using the egl drivers from my 1.7 ROM in /lib/egl
              As well as all the stagefrightxxx.so files from 1.7 in /lib
              I dont have time today to mess with it but if someone wants to try it, go for it.
                Same here...
                  I can make a zip who do that, but i need a guinea pig, someone?
                  My devices:
                  Gearbest.com)
                    ok make tha will test it
                      Re: cwm recovery zip for the new libstagefright.so
                      Sorry time to dinner with family, tomorrow I will try to make it and will send you the link in pm.
                      My devices:
                      Gearbest.com)
                        ok
                          ok i have the zip to test the new lib in ug802 devices and clones, please is a test file for the people who can´t boot after change the libstagefright.so, like Bob said, lets try to add the new mali libs in /system/lib/egl and all stagefright stuff.
                          I check that the zip works, but i cant test in the ug802 and clones.
                          Here is the zip and I need a tester and feedback:
                          Pls make a nandroid backup before try it. Thanks.
                          My devices:
                          Gearbest.com)
                            Ok zambu tested the new one and it works, thanks to Bob who gives us the solution. Seems that you can use the new patch safety.
                            My devices:
                            Gearbest.com)
                              i will be testing it in 2 days due i broke the micro usb connector when did try to flash it. so i will need to wati grrrrrrrrrrrrrrr
                              Thanks for y our excelet work.
