MK808B no longer works
I'm a bit new to the MK808B so please excuse me but in the last day my MK808B has stopped working. Dolphin browser kept crashing, 1channel no longer functioned, app store stopped working and gradually all of the apps stopped working. I tried deleting some apps so I could re-install but the MK808B froze and when I switched off and on the app was still there. The device boots up and gives me the screen with my apps on but if I click on any app a new screen appears as if all is well but then I'm taken back to the initial boot screen. Due to lack of a power off button I've been just switching of the power at the mains which looks as though that was not a good idea. But to recover can I just install new firmware (eg. Finless)? What about the operating system - will that be OK and will I loose all my apps including those that were pre-installed. Sorry about the basic questions but help would be appreciated to get my MK808B working again.Tags: None
To install new firmware (eg. Finless), you should erase NAND, which means you will lose all your apps including those that were pre-installed. You will have to reinstall them from Google Play.
Download the appropriate Finless ROM for your MK808B and follow the directions in his readme text file. You will end up with a rooted Android 4.1.1 device.MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
Re: MK808B no longer works
Yes, be sure about what mk808b you have, and get the proper Rom, if not, WiFi and bt dont workREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View Posthttp://www.FreakTab.com/showthread.php?t=3880
Here is some information.
Originally posted by terry29946 View PostThanks for your help guys - now up and running with Finless 1.7. Great!___________________________
MK808B (Genuine) w/Finless 1.7
Originally posted by zuberio View PostOS corruption may also be due to using the stock power supply. I've ordered and am currently waiting for a PS Vita charging cable that outputs a more stable 1.5A 5V USB power supply. Others on this forum have indicated it's a good choice for the MK808. You may want to think about this if you haven't already.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 4035 users online. 2 members and 4033 guests.
