[KERNEL][CWM ONLY][Mar14] Omegamoon's Kernel Compilations for MK808 only
Originally posted by PoisonWolf View PostREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by PoisonWolf View PostWhat rom and what device are you using ? Installing via CWM?
and I've installed it using CWM and using Finless Flash Tool, same result, I got it to boot (after about 10 bootloops) but it was very slow and unstable, and every time I rebooted i got into yet another set of bootloops, so I reverted and I gave up on it
2dark4u is the only kernel (other that stock and finless) that works for me
Originally posted by lukesan View PostIs there a way to upload these files on a location where I do not have to sign up for spam?
Originally posted by lukesan View PostJust done the test.
Sorry for the record quality. 720P kernel but recorded with my S2 in front of the tv. Same channel, the Omegamoon one might be recorded closer to the tv but I think you will see what I mean.
and
http://www.youtube.com/watch?v=3aWpY...ature=youtu.be
Let us know what happens.
Originally posted by PoisonWolf View PostVery interesting problem. Two things we could try. First tick both force GPU rendering and disable hw composition under developer options and let me know if the stuttering persists. Of it does....try to lock the CPU speed to 1.2 or 1.4 GHz and see if it still stutters.
Well actually tried two things. Locked the CPU to 1.5GHz on Omegamoon and ticked GPU rendering.
Need to check if I can use the recorded TS files from the sat and post them on my webspace or so just to make it easier to see what is going on.
Originally posted by PoisonWolf View PostYeap that happened to me when I came from 2dark4u kernels. I had to do a clean install and select the .IMG file to begin with when installing with the flash tool. Sorry that you can't try this kernel. Enjoy your device regardless !
See bugmenot. Another user posted it earlier in the thread.
Originally posted by niabi View PostProblem is I was not coming from 2dark4u kernel... it was a clean flash after 1.7c... but I don't think I've tried flashing the kernel instead of the 1.7c version...
Originally posted by lukesan View PostWell actually tried two things. Locked the CPU to 1.5GHz on Omegamoon and ticked GPU rendering.
I have Finless 1.7A Rom with kizs Kernel 2.1 720 P on my Mk808
What is the best way for me to update my MK808 with Finless 1.7c and with Omegamoon's Kernel ?
Shall I use the RK Flash tool in finless rom and change the kernel img to Omagamoon's Kernel file ?
Or shall I flash with 1.7C Rom first and then flash kernel with CWM ?
please help.
Originally posted by Omegamoon View Post@lukesan, could you please share the link so we can use this as a common test case?
Aha Omegamoon. Well I will pm you the link as PoisonWolf could play it perfectly on his. So it might have to do with data transfer.
I see you are from NLD which could make a conversation and test handier.
Originally posted by lukesan View PostAha Omegamoon. Well I will pm you the link as PoisonWolf could play it perfectly on his. So it might have to do with data transfer.
Now... Still have to get the MK808B Wifi/Bluetooth working
Re: [KERNEL][CWM ONLY][Mar14] Omegamoon's Kernel Compilations for MK808 only
Originally posted by Omegamoon View PostGlad that is sorted out then. I haven't had any issues with dropped frames, so I was surprised to read this.
Great work, I am sure that you will get itREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 3007 users online. 0 members and 3007 guests.
