[KERNEL][CWM ONLY][Mar14] Omegamoon's Kernel Compilations for MK808 only
    Originally posted by Omegamoon View Post
    Glad that is sorted out then. I haven't had any issues with dropped frames, so I was surprised to read this.
    Now... Still have to get the MK808B Wifi/Bluetooth working
    Well not sorted out for me when I stream via wifi.
    I have 2 MK808's and both show the same. One is the first model they made and the second one is one of the last ones.
    I did not try the file directly on the memory of the MK808 when using your kernel yet, which I hope to do tonight (if I find a free minute).
      This is what I did to mine to run @1.6GHz. It's a chipset heatsink off an old Asus P4P800 motherboard. Then some vram heatsinks on the NAND and memory.
      TV Stick: MK808 // Tronsmart T428
      ROM: Finless 1.7c w/Pimp My Rom // Nexus SDK2 Multi-Window v1.2
      CPU: @1.6GHz OnDemand Governor NOOP I/O Scheduler
      Recovery: ClockworkMod
      Kernel: Omegamoon // 1080p OC kernel 720ddr 1.9cpu
      Phone: Samsung Galaxy Note II
      ROM: Whompasaurus v4.2
      Kernel: Persus
        Just tested with my 2 MK808's
        Running Lewy 2.11 and either Omegamoon or Alex kernel. Omegamoon on performance 1.6GHz locked and Alex on 1.4GHz locked.
        The file copied locally so no network slowdown. Seems like 10fps on Omegamoon and full speed on Alex kernel playing via Archos player.
        Omegamoon can you test?
        If anyone wants the file pm me : don't want to put the file publicly on the net
          Try enabling 2d GPU rendering for omegamoon's kernel. I know Alex may be running the GPU at 266 and up and that he runs the DDR RAM at a higher frequency than usual. Not sure what else he could have changed that would result in these performance differences...
            Different host?
            Thank you for making the kernel available for our little toys. Your work, as well as that of all those who contribute to this great little community is greatly appreciated.
            Please consider hosting the files on a server that does not require an annoying, time-wasting sign-on. Perhaps dropbox?
            ...W.
              ...W.
              Bugmenot. They have shared logins just for things like this.
              P.S. I didn't make these kernels. I just compile them. Omegamoon made these kernels. =)
                Yes, I know about bugmenot; I had to use it to download your offering. It would have been great not to log into yet another site and try a couple of passwords to find one that works. But I understand if you don't have the time to set up something else.
                BTW, the kernel works quite smoothly on my original MK808 with 1.7c. Thanks to Omegamoon and you.
                  Glad that it works great for you. =)
                  To everyone else: Direct mirrors have been added to the download links in addition to the 4shared links.
                  Hope this saves people the time from having to use bugmenot.
                    Thanks for the quick link fix!
                    Now its so much sweeter.
                      Tried it all but no go.
                      Can you tell me which rom you use and which player if you say the file didn't have dropped frames on yours?
                        I use Finless 1.6 and I use MX Player, played locally.
                          Could someone please pinpoint me in the right direction on how to implement the init.d script for the sound fix on 720p?
                          A file ready to put in the right directory would be awesome
                          Does this kernel bring any additional performance in SNES emulation? I need the scrolling in Super Mario Bros 3 of Super Mario All Stars to be 100% fluid
                          Thanks for the hard work omegamoon, please fix the no sound issue on the native 720p kernel.
                          Thanks a lot!
                          Tek.
                            Download script manager I believe from the store.
                            finless explained it in the first or second page .
                            Thanks a lot!
                            Tek.
                              Re: [KERNEL][CWM ONLY][Mar14] Omegamoon's Kernel Compilations for MK808 only
                              It works on mk808 with stock rom (JB 4.1.1)?
                              Kind regards,
                              Jorge
                              Sent from my ST23i using Tapatalk 2
                                Originally posted by Jorge Moreira View Post
                                Kind regards,
                                Jorge
                                Yes, it should work with stock.
