WiFi notification bar info 00:00:00:00:00:00
I notice both these folks with this issue (showing pics) are running some other launcher! So I think it is something with that.
Originally posted by Finless View PostI notice both these folks with this issue (showing pics) are running some other launcher! So I think it is something with that.
Odd, I will have a look at 1.7a and see if I can figure out what is going on.
Originally posted by dElA View PostSame here, stock launcher, 1.7a, MX1...Flashed 1.7b. All ok.
Originally posted by keithsipa View PostConfirmed on mk809ii, flashed with 1.7b and it now shows my real SSID name in the notification bar instead of 00:00:00:00:00:00.
Not yet sorry.... Been too busy with new ROMs and other fixes.
I will get into it though no worries.
In the next week or so expect a new ROM based on the new neo X5. I like some features that added so I am going to port them over.
But this will take awhile and I am going on vacation for 4 days. It's my Wife and I's 30th anniversary
Bon"Pzebacz im, bo nie wiedzą, co czynią"
Lucky first one
First of all Thank You!
Lucky for me that I've found this thread, been using your 1.7a rom on my iMito mx1, and been meaning to ask you about two things, one was just the "00:00:00:00:00:00" message wich also appears on mine. Dumb of me I was actually thinking that was some sort of counter for the time you spent connected, didn't realize it was a mac address till I read this thread...
The other "problem" is a bit more annoying, I'm connected wirelessly and every single time I shutdown and restart the iMito the date and time are not saved.
I'm not always able to connect to the wifi and sometimes when I try to, it says the certificate (yep wifi I'm connected to does that) has expired and that the dates mismatch, the problem being that my iMito is stuck on 01/01/2000 or something like that.
Do you think you might look at that also? Is it just me with the date and time not being saved?
I actually don't remember how it went with the stock rom, mainly because I didn't give it enough time, eheh, first thing I did was root and then flash your rom.
Thank you once again.
Originally posted by Finless View PostThere is no battery in these so they do not hold time on a reboot. It must get time from the network. If your getting the wrong time then either your routers time is wrong or your ISP NTP time server is wrong.
If you give me a logcat dump I can look and sere where it is getting time from and why it is off.
There are currently 2999 users online. 0 members and 2999 guests.
