Customize Finless 1.7 - Preinstall App in ROM
Originally posted by [email protected] View PostHey guys,is it possible to customize the rom and "preinstall" a few Apps on it? I need to flash a few MK808s and want to save a bit work.Coul'd someone help me with that?Thanks
Use cwm. Also a nice way to have a backup when they mess it up.
I guess you don't want a user account on it so get the apk's, install them, test and then back it up via cwm on a sd-card and recover on the other devices.
Originally posted by [email protected] View PostThank you!I need to flash 200 Devices. If i want to use cwm i need to root each device at first, right? The easiest and fastest way would be, if i could customize the Finless 1.7 Rom and just flash it on each device.
Correct that should work! To be honest make small steps and note down the versions like ver1 (set time zone) ver1.1 (add videoplayer) etc
If you could make a complete img that would be even easier, then you would not have to make all the steps just flash it in one go. Maybe Bob can help you with that.
Found a solution.On Ubuntu you can mount the system.img File. And there i could easily add my apk's to app-Folder. Used this tutorial(it's german, but t think one can recocnize the important commands. if someone have the same problem!):http://www.android-hilfe.de/root-cus...earbeiten.html
There are currently 2669 users online. 1 members and 2668 guests.
