So i've spent all morning and afternoon reading this forum and the finless 1.7 thread and googling and reading and re-reading the readme file included in the install package...(The PC mentioned in this post is a Samsung Series 9 running Windows 8 professional)
I first followed the instructions in the readme.txt and could not get the ROM Flash Tool to recognize my MK808b at all. I have enabled usb mass storage and turned off USB debugging, as well as checking and unchecking the "connected to pc" box in the settings menu. Next I tried the RK Batch Tool and followed the same procedures with no luck (the box never turned pink). After both of these methods failed, I tried to put the stick into flash mode by pressing the hidden button with a pin and connecting to my laptop via OTG. When I tried to load the drivers windows tells me that the driver install has failed (win 7 x64 are the drivers I chose because there is no win 8 option...also, I have disabled the driver signature verification in win 8 so that should not be a problem). I have a win xp pc at my disposal but it is not very reliable, and I'd really like to be able to complete this process with my pc. I am looking very much forward to using this rom on my MK808b, and I am waiting til after I get Finless installed before I really start setting up my Android. Any help I recieve would be amazing. Thank you.
