XBMC - Hardware Accelerated Decoding - What works and what doesn't.
this update just implement 19.02 build hw into newer build of xbmcEverything is possible if we work together!
Originally posted by lewy20041 View Postnew xbmc hw ver. http://mirrors.xbmc.org/test-builds/...rmeabi-v7a.apk
Thanks for the info! Can you maybe specify what live stream you are talking about (and maybe using what plugin?)
I'm using it to stream files of an FTP server and that works fine so far. Not a live stream of course.- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
- MK808 with Finless MK808 1.7c ROM and 2Dark4U 1.4 MK808 1080p overclock kernel.
- MK908-II: XBMC full 1080p playback with a 1080p kernel HERE
i made a fix for streams.
unpack thease files http://d-h.st/lQB into /system/etc/
set permisions "rwx --- ---" to install-recovery.sh
this way it load fix at startup.Everything is possible if we work together!
Just rename the script to 00script.sh
copy it into the init.d folder.
reboot
Lewy20041: Thanks for your info and fixes. You seem to know your way around XBMC and android.- UG007-II with Finless iMito MX1/2 1.7a ROM and UG802 2Dark4U 1080p overclock kernel and USB WIFI dongle.
librtmp.so
librtmp.so.0
install-recovery.sh
to /system/etc/ and have set the permissions to all the 3 files to "rwx --- ---", still XBMC crashes on live streams like BBC Iplayer or ITV.
Bob, I also tried copying librtmp.so and librtmp.so.0 and renamed the install-recovery.sh to 00script.sh
and set the permission to all 3 files, still the same error. what did I do wrong
Originally posted by Wizzy View PostBob, I also tried copying librtmp.so and librtmp.so.0 and renamed the install-recovery.sh to 00script.sh
call it 01script not 01script.sh
Sorry about that.
Also permissions need to be set on the script.
Using ES file explorer,
Long press on the 01script file and select properties from the list.
click the change button to set permissions
click ALL the boxes except the last WRITE box.
Or from a terminal type this
su
chmod 775 /system/etc/init.d/01script
Originally posted by Finless View PostI made a mistake in what I said. Do not put a file extension on the script name.
Sorry about that.
su
for me its working nice:"
try manualy copying librtmp.so and librtmp.so.0 to /data/data/org.xbmc.xbmc/lib/ and set permisions to "0755" "rwx r-x r-x"
you have a rooted firmware right?Everything is possible if we work together!
more importantly no dropped frames/choppy video on Amazon prime videos, will test on sportsdevil streams and report.
im glad its working for you, but you need to script it otherway you will have to do this every time after reboot.Everything is possible if we work together!
Most files are work right
Originally posted by lewy20041 View PostFor XBMC HW 19/02/2013 you need to create advancedsettings.xml to have more resolution and formats unlocked.
Koying purposly locked some becouse they are not stable but you can try it if you wont.
Code:[COLOR=#000000][FONT=monospace]<advancedsettings>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace]...[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] <video>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] <stagefright>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] <!-- -1 is default, 0 is never used this codec, 1 is always use this codec, bypassing blacklist -->[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] <useavccodec>1</useavccodec>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] <usevc1codec>1</usevc1codec>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] <usevpxcodec>1</usevpxcodec>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] <usemp4codec>1</usemp4codec>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] <usempeg2codec>1</usempeg2codec>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] <useswrenderer>false</useswrenderer>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] </stagefright>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace] </video>[/FONT][/COLOR] [COLOR=#000000][FONT=monospace]...[/FONT][/COLOR] [COLOR=#000000][FONT=monospace]</advancedsettings>[/FONT][/COLOR]
Use xbmc 13-alpha1 hw-accel version and advancedsettings.xml
720P works great~~
1080P is little bit laggy but affordable.
Thanks~~~
There are currently 1739 users online. 1 members and 1738 guests.
