Add touch screen support for Six Axis/Joy Center to my ROMs
Here it is flash it from cwm recovery:
REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
just some info:
to make vtouch screen to work you need to change degree to -90 in sixaxis app settings.Everything is possible if we work together!
Re: Add touch screen support for Six Axis/Joy Center to my ROMs
Originally posted by lewy20041 View Postjust some info:
to make vtouch screen to work you need to change degree to -90 in sixaxis app settings.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Guest
Hi Bob, first of all, thanks for the great guide and ur constant support. Now, I've followed all the steps here (I'm using your 1.7b firmware for MK808, on my MK808 of course) and I can see the Virtual Touchscreen module loaded (it appears first on the list when I do the LSMOD), but... I still have the same problem with my JoyCenter 6 apk... I can see my joy, assign buttons, activate the joy2touch server, I even get a message saying I have real mouse, real keyboard and virtual mouse (with Protocol B activated) but no matter what I do, when I go into edit mode to assign touch functions I cannot ADD any buttons, I can see the EDIT screen but I cannot see any button or trigger or anything else, I cannot either add anything....
Any ideas what could be wrong ?
Thanks.
2 Requests/ Questions After Thank You BOB :-)
First of all I want to thank you Finlessss for this great progression!
Yes,, now I really get what I was looking for long time! Waiting for this moment that make my TV stick a complete entertaining device!
Thank you finless for all your efforts.
Yes, I tried this with sixaxis and it works perfectly!!
I tried this also with my xbox joystic via usb/joystic center but it cant recognize my wired x-box joystic, it keep lighting on and off, really didnt know why?
I am using latest mx1 beta finless rom on my UG007.
I also tried an app called gamekeyboard but touch emulation not worked!? Please look for this!!!
Now my 2 requests or questions are:
1) I noticed that the bluetooth signal is weak and lost between my TV stick andd PS3 controller when go away more than 3-4 meters!
so, if I purchased external USB bluetooth stick for better signaling, can it be recognized and used by sixaxis app instead of built in UG007 bluetooth without problems?
2) Can I use directorybind app to move data of games from SD to USB storage rather than ext-SD ?
Can I make my device to see the USB storage as SD card and the SD card as mass storage?
Thank you very much, really thank you
Originally posted by Haris1977 View PostBob , will this add touch screen support work with official mk808B stock rom? My rom is 401_j1_#26
EditI cannt use this method. I dont have a system/etc/init.d folder. Is there smth i can do??Can i create one?
Please help
Do you have any original MK808B?
Hi, was wondering if anybody could help alittle. I've got an MK808B w/ finless bob 1.7.
I've successfully install the virtual touch driver. I think so because I see do see it in the list with lsmod.
So I'm a little lost on how it works with sixaxis. I see a Type B virtual touch message on start up and I connect the controller. The controller is working fine. I just don't see it doing anything with the test profile I set up. Is there an order issue? If you have a mouse also connected (2.4ghz) will that interfere?
Thanks...
go to sixaxis settings and change degre to -90:"Everything is possible if we work together!
Originally posted by lewy20041 View Postgo to sixaxis settings and change degre to -90:"
But nothing from sixaxis. Is there anything else I can use to perhaps debug this. So far everything says working in some way (the type b seems suspicious but I honesty don't know) but there's no output from the sixaxis controller for the touchscreen.
Touch emulation not working
i used your latest minix hybrid rom with MK808B
the six axis controller is working well,
my problem is the touch profile wont work, i currently
trying to set up nova 3 profile. Everything is connected
but the touch emulation wont work. (i can use only fire button
the analog left and right is not working)
the mouse emulation works in the nova 3 game but it very
odd playing it this way.
Do i miss something....please advise.
thank you
ricont
thank you
ricont
I installed back to finless 1.7 720p ROM on my MK808B, I patched the touch.zip from Leolas.
I run the six axis controller app, connected ps3 (original) dualshock3 controller.
Load the Nova 3 touch profile ( google pls ) and it successfully able to have touch
emulation with the NOVA 3 game.
Excellent work to BOB for his GREAT ROM and also to Leolas for his support to this site.
I am very HAPPY with this ROM.
Brgds
ricont
Brgds
ricontREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 3011 users online. 0 members and 3011 guests.
