Add touch screen support for Six Axis/Joy Center to my ROMs
Guest
Hi, I'm kind of lost here... what do you mean with "I patched the touch.zip from Leolas" ?I'm also using BOB's 1.7 on my MK808B and followed the steps to be able to run the init.d touch script and everything seems to be ok... I can see the touch module with LSMOD , I change Sixaxis to -90 but still, touch doesn't seem to work. Should I use the touch version provided by Leolas instead of the module at the begining of the thread ? Cause I don't know what are we talking about when you say "patched" version of touch.Thanks for your help.
Re: Add touch screen support for Six Axis/Joy Center to my ROMs
Originally posted by Mopheus View PostHi, I'm kind of lost here... what do you mean with "I patched the touch.zip from Leolas" ?I'm also using BOB's 1.7 on my MK808B and followed the steps to be able to run the init.d touch script and everything seems to be ok... I can see the touch module with LSMOD , I change Sixaxis to -90 but still, touch doesn't seem to work. Should I use the touch version provided by Leolas instead of the module at the begining of the thread ? Cause I don't know what are we talking about when you say "patched" version of touch.Thanks for your help.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Guest
So it should work... any ideas then how I can check what could be the problem ? Sixaxis connected my PS3 joy without problems, I created a very simple touch profile but yet, doesn't seem to work... module seems to be loaded (Virtual Touch screen does appear in position 3 on the list when I do a lsmod, can this be a problem ?)... Sixaxis changed to -90... I really don't know what could be wrong... permisions on the files maybe ? But I gave both script and ko full write access to everyone, just in case....
Originally posted by Mopheus View PostSo it should work... any ideas then how I can check what could be the problem ? Sixaxis connected my PS3 joy without problems, I created a very simple touch profile but yet, doesn't seem to work... module seems to be loaded (Virtual Touch screen does appear in position 3 on the list when I do a lsmod, can this be a problem ?)... Sixaxis changed to -90... I really don't know what could be wrong... permisions on the files maybe ? But I gave both script and ko full write access to everyone, just in case....
I used Leolas cwm flash zip.
when i run my six axis controller app (version 6.4)
TOUCH EMULATION (TYPE B): 0 1920 0 1080
SUCCESSFULLY CONFIGURED BLUETOOTH
LISTENING FOR CONTROLLERS.....
CLIENT 1CONNECTED
can you check if the touch emulation (type b) ...........
is the same? last time I used Lewy Hybrid ROM the
number is different.
my one cent idea.
Brgds
rico
CLIENT 1CONNECTED
my one cent idea.
Brgds
rico
Originally posted by mwneuendorf View PostMine is 0 255 0 255 Which can't be good most likely. Not sure where it's getting pulled from though. I'm pulling the sixaxis off the store. Fresh install. Maybe some place you can set it?
I suggest
1 Fresh Install finless 1.7 720p
2 Read the CWM recovery for rk3066devices made by Leolas and have CWM on your MK808B
3 Flash touch zip
4 Install six axis apps and run, connect the dual shock3 controller .
I hope you got the touch emulation type b 0 1920 0 1080
Thank you
Guest
Well, mine is also saying 0 255 0 255 !! I think that's the problem... I'm running my device in 720P so I think for some reason is not detecting resolution fine... I'll try to go CMW way (not sure how to do that but will do some searching) to try to flash the Leolas touch.zip instead of Bob's mode and see if that solves my problem. I'll also try playing with screen resolutions to see if that helps or changes anything.In the meantime, if anyone finds a solution, please post it ! I really want my touch emulation... (Although Developers should really start thinking on gamepad support for all games, it's really anoying to think Android is only used with touchscreens these days...)Thanks !
My cwm zip is exactly what Bob says in first post, the honors to him who found the way, I simply made a script in cwm for an easy install, but if follow Bob's steps without errors is exactly the same that my cwm zip does.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
the difference in resolution return numbers makes me think this is a hdmi edid issue. I've seen in other forums returns of the proper resolution numbers 0 1280 0 720 and 0 1920 0 1080 for the sixaxis app and other posters here also. Values like 0 255 0 255 is most likely the TV returning bad values via the HDMI. I'll be emailing the developer of sixaxis. They might be able to do something.
Guest
Originally posted by mwneuendorf View Postthe difference in resolution return numbers makes me think this is a hdmi edid issue. I've seen in other forums returns of the proper resolution numbers 0 1280 0 720 and 0 1920 0 1080 for the sixaxis app and other posters here also. Values like 0 255 0 255 is most likely the TV returning bad values via the HDMI. I'll be emailing the developer of sixaxis. They might be able to do something.
FYI, flaky HDMI cables can in fact cause bad EDID reads!
I have seen it happen and I have 2 cables with that exact problem.
Guest
Well, I tried all the diferent resolutions and cables and no luck, with my projector I cannot get EDID information, or at least it seems so. Tonight I'm gonna try to connect my MK to the TV and see if it works there... but I was really hoping to use it on my projector, so my only hope is Sixaxis fixing the problem (that by the way, it's also affecting USB/BT Joystick Center apk, it seems both uses EDID, cause it also has problems with touch profiles)....Thanks.
Originally posted by Finless View PostFYI, flaky HDMI cables can in fact cause bad EDID reads!
I just try Lewy's ROM 1080p V2.2.2 on my MK808B to create Sixaxis touch profile without problems (Must change oriental offset to -90 degree). You don't need to add touch.ko for this ROM. Lewy already added touch module into ROM ready for use. You just need Sixaxis app and your PS3 controller. My device is MK808B (Original from Geekbuying) connect with LG PB60g projector with PS3 controller (fake PS3 controller by Chromo Inc from Amazon) and Sixaxis app 0.6.4 all work great to create touch profile for game.
There are currently 1947 users online. 2 members and 1945 guests.
