New in 0.31:
- init.d fixed
Features:
- Based on latest stock Polaroid ICS
- Rooted
- Latest Google Play installed by default.
- Busybox updated to latest version
- init.d support by default
- Scripts for speed added (See note above)
- Latest CWM recovery
- Petrus' 'Reboot' application. Features:
- Reboot
- Power Off
- Reboot into CWM recovery
- Apex Launcher enabled as default launcher
Thanks to: 900supersport, petrus, Tattman65, Finless, LiquidLimez
Installation instructions:
***NOTE: IF YOU ARE FLASHING FROM THE STOCK ROM, PLEASE REMOVE YOUR EXTERNAL SD CARD BEFORE FLASHING-IF YOU DO NOT, YOU MAY LOSE YOUR DATA!!!!***
- Follow these instructions with the exception noted below (No reason to re-invent the wheel): http://southerntelecom.com/polaroids..._pmid703C.html
- In step 17, instead of using "PMID703C_Firmware_4.0v3_OTA.img", you'll obviously want to select "703C_elektricity_rom_v_03.img". Note some folks have had trouble flashing-if so, just rename my file to "output.img" and it should flask ok.
- 'LET IT SIT' for at least 5 minutes before doing anything to let the ROM "Settle".
- Reboot (I just added this step as a 'just in case things aren't quite working the way you want')
Problems after you flash?:
PLEASE DO NOT REPORT PROBLEMS IN THIS THREAD until you've confirmed you followed the above instructions EXACTLY. Please don't report the problem in this thread until you've tried a factory image install first to see if that cures the problem.
CHANGELOG:
See post #2
DOWNLOAD (New location):
