It is not so difficult to made it by the fact all people can do this following this thread:
http://www.freaktab.com/showthread.p...ke-a-look-here, but a lot of time is needed for make all zips for all roms, so I will release some Finless roms every day.
ADVICES:
Roms was made by Bob Finless, not for me, I only made the cwm scripts, so all thanks to him for gave us all those fantastic roms.
And please comment how they works and give thanks to Bob in their roms threads, comment here only if you have issues with this install process.
The cwm recovery was ported to rk3066 devices by fun_ from http://androtab.info/clockworkmod/rockchip/ thanks to him for all his great work.
I only made the cwm scripts so i think is the easier mode to flash roms if you have the stick away of your computer.
Requirement:
You need a microsd card where you copy the zip for your specific device. The microsd must have at least 500mb of free space after you copy the zip to the device, because 500Mb of this microsd is needed in the flash process.
I suggest you to make a cwm backup of your current rom before flash the new rom, if something goes bad you can return to the original state without problems.
From cwm we cant resize partitions, so if you come from stock rom, i suggest you the first time use a windows pc to flash so you can use the advantage of a great data partition with more space to install aplications, the 512Mb for apk who comes with the stock rom is very low in my opinion, so 2Gb for our apks is a great advantage. So first time you install a Bob finless rom is better to do it from a windows pc.
Today the first devices are mk808(rk901) original and mk808b(rk903) original, each device have 2 roms available 720p and 1080p. Both use the original kernels that comes with Finless roms. The 1080p kernels i will use are patched by Bob from the original one, except the mk808(rk901) who was patched by Dero, thanks to him too. Bob has a thread explaining about patch kernels to get 1080p.
mk808(rk901) "original" 1.7c Rom made by Bob Finless:
720p:http://cloud.freak-tab.de/public.php...183fef76f14fe6
1080p:http://cloud.freak-tab.de/public.php...847a9b060fb5d7
mk808b(rk903) "original" 1.7 Rom made by Bob Finless:
720p:http://cloud.freak-tab.de/public.php...cb49fa390c88ff
1080p:http://cloud.freak-tab.de/public.php...68b1b1bff0fdbd
Now time for other 2 roms sunvel mk808b clone and clonev1, i cant test them cause I dont have those devices, if you use them please report if it works:
mk808b sunvel clone NOT TESTED YET:
720p:http://cloud.freak-tab.de/public.php...9776379a55b261
If you want 1080p kernel in this device, then after flash the 720p version you need to flash this:http://cloud.freak-tab.de/public.php...7aa72e64b321d4 this change the kernel and the boot image.
mk808b clone v1 NOT TESTED YET:
720p:http://cloud.freak-tab.de/public.php...052b155e1e45be
Bob didn't patch this device to 1080p yet.
MD5 hash:
File Name MD5 cwm_mk808_Finless_1.7c_720p.zip DEC453DE98F5299A075ACD41F6183077 cwm_mk808_Finless 1.7c_1080p.zip D64328E379AE64C5BBA0FAE8ED2086C6 cwm_mk808b(original)_Finless_1.7_720.zip 4BA66AA70020EE6960EC7E728714EB9F cwm_mk808b(original)_Finless_1.7_1080p.zip 33DA2FA82D025422809B5CA81B0A13FD cwm_mk808b_sunvel_clone_finless_17.zip E29A21D8554CD0A4573C435FF081D8B0 1080p_1.7_sunvel_clone.zip D34F55A630D5CD4856A397DB9CA0E238 cwm_mk808b_sunvel_cloneV1_1.7 Finless.zip CC2A364B76DDF8096919F6E32D2EDE81
The new quads have not their specific images uploaded to androtab, when we get funtional recovery for the new quads devices i will make the flashable zips for them.
