CWM recovery flashable zips for all Bob finless roms.
    Originally posted by leolas View Post
    EDITED: MD5 hash available in the first post
    Thank you, leolas! The download made it through unblemished.
    ...W.
      leolas,
      congratulations you made it so easy.
      I think this post must be up.
        Re: CWM recovery flashable zips for all Bob finless roms.
        Thanks a lot, but remember please that Bob makes the roms, and he made all the hard work.
        My devices:
        Gearbest.com)
          Update.zip for hybrid v2.2.0
          Thanks for your work can you please make update.zip for hybrid v2.2.2 for mk808b?
          or please post a guide or link on howto make it on mac?
          please
            please
            I sent lewy the zips structure and the script, he will made them when he can.
            My devices:
            Gearbest.com)
              much appreciated a finless 2.1, cwm flashable zip
              tried with the instructions from the 1st post but got stuck at flashing, not sure why and didn't had time to troubleshoot
              thank you & keep up the good work
                Not possible to upgrade to 4.2.2 from 4.1.1 using CWM.
                CWM cannot repartition NAND. The new 4.2.2 kernel is larger and thus NAND must be repartitioned to fit.
                Only way to do that is with the flash tool.
                  Yes, I am going to pst it in the first Post.
                  My devices:
                  Gearbest.com)
                    How about flashing 4.2.2 Finless 2.1 ROM on a 4.2.2 rooted MK808B original RK903 using CWM?
                    Thank you in advance.
                      I think that it is possible. Make a cwm backup in the external sdcard, and then try it, if it fails only need to restore the backup.
                      leolas
                      My devices:
                      Gearbest.com)
                        leolas
                        Great!
                        Would it be possible for you to make the Finless 2.1 ZIP files for flash with CWM?
                        Thanks Leolas.
                          I will do it, but remember that it will work only for the devices who have the stock 4.2.2 or Finless rom 2.1
                          leolas
                          My devices:
                          Gearbest.com)
                            leolas
                            Understood.
                            Thank you Leolas ... you're the man!
                              i Don't know if this thread is still active,but is this ROM good for the MK809 II? As I've been trying to find ROMs for my device that I can install via cwm recovery. Hope someone can help. Thanks.
                                Look at 3188 section I made a template-zip that can be used to flash any Rom frim cwm, you only need to add it system.img, kernel.img and boot.img
                                leolas
                                My devices:
                                Gearbest.com)
