There was in issue in my previous kits that status bar notifications where skewed way over to the right. This is fixed. However this V3 kit only contains the 100% transparent status bar. I will work later on 30% and 50%.
I also updated the readme as some file explorers when a file is copied from SD Card does not set the file permissions correct (execute and write) and some users were still getting a blank status bar! So read my instructions at step 11 to fix that (Daman
I have updated the download link to the new kit. The file name is now V3.
_________________________________________
OLD UPDATE Feb 26 2012!
My new kit now includes not only 50% and 30% but 0% for a totally clear status bar! Only the icons show up!
I have updated the download link to the new kit. The file name is now V2.
Does the status bar kinda tick you off?
Got a book reader app or another app that the status bar covers up?
Well I know I hate the thing. I will continue work on an APP to actually make it hide and return
but in the mean time I moded the SystemUI to make the status bar see through!!!!
In this kit I provide full install instruction so read the README.txt!!!
Also in the kit are two version. One is 50% transparent and the other is 30%.
I prefer the 30% myself but you get a choice!
Anyway I hope you enjoy my first mod! Here is the download.
Download-> Transparent Status Bar Mod V3 by Finless (1.4 megs)
Enjoy,
