I have to use GIMP and then make a .9.png format which is all new to me.
The reason the others were off is because after de-odexing by hand SystemUI.apk, I then used UOT kitchen to make the changes. As you can see it busted it and moved the notification message because UOT kitchen only supports phone resolutions and not tablet resolutions.
So after that issue I learned how to make the changes myself by hand! Now making 30% is a lot harder as I am not good with GIMP yet. In GIMP all I did was erase any color and left the bar image transparent. TO make 30% I have to learn in GIMP how to do a 30% shading. Not easy when your starting to use an application you have never used before!
So you will get what I have and later I can work on other levels when I get more familiar with GIMP.
