ROM for the new MK809IV Quadcore??
    Originally posted by darekmarta1975 View Post
    I have firmware:
    Android 4.1.1 https://hotfile.com/dl/225374476/557...4.1.1.rar.html
    Android 4.2.2 https://hotfile.com/dl/224829641/82f...4.2.2.rar.html
    password darek1975
    PS.
    Android 4.1.1 does not work on SKYPE webcam Logitech (antutu 14000)
    Android 4.2.2 is faster and more stable(antutu 15400) also works every version of XBMC,but the problem with SKYPE
    Just flashed 4.1.1 rom, 4.2.2 was very buggy with wifi, dropped speed to 2/3mbps a few minutes after connecting... 4.1.1 is better with wifi, but the rom is not rooted. What's the correct procedure to root the 4.1.1 rom? Many thanks.
    I found this (http://blog.geekbuying.com/index.php.../#.Ubt185xjFbo), but it doesn't work, it always says "error: device not found". I have the drivers installed, or else I wouldn't be able to flash roms and I also have usb debugging option enabled on settings. I tried plugging the device to the pc with and without the flash button previously pressed, when I don't press it noting happens, when I press the button the windows notification sound is heard and it appears as Rockusb Device.
      ROOT doing the RK3066 processor
      I suggest you connect your device to your TV and laptop with you, so that you can easily zrotowac:
      Use a DC power port device and use the OTG port to connect with a laptop MK. (Ie the OTG is the mini usb with card reader)
      1) Download ROOT RK.zip and extract it to a folder.
      ROOT RK.zip
      2) Install and open it Moborobo (file is in the ROOT RK)
      3) Make sure that USB debugging is enabled in the MK (go to "Settings" - "USB", select "Connect to PC chooice"
      and then go to the "Developer options" open "USB debugging" option)
      4) Wait Moborobo detect the device and install the drivers. Detects the device as the RK Series.
      5) Run TPSparkyRoot.bat and follow the onscreen instructions.
      MK reboot 3 times during this process. (Please note, after each reboot, select "Connect to PC" every time in MK,
      if you do not choose to root, that is the reason why I asked you to connect MK with TV and a laptop together)
      Once done, go to the next step.
      6) Install SuperSU the store Play. (If it is not installed in the previous step)
      If all goes well, we should have root
      MY MINI PC: C4,CS918,M8,M8C
        ROOT RK.zip
        Many thanks, I will try this and report back.
        Can you please tell me the password to extract ROOT RK.zip?
          the same as in firmware
          password:darek1975
            password:darek1975
            Thanks, but the device is still not detected.
            After installing Moborobo, how do I connect the mk802iv to the pc:
            Using the otg port and pressing the flash button before I connect it?
            Do I use a power cable to turn on the device and only connect it to the
            pc afterwards using the otg port, but without pressing the flash button?
              Connect the cable from the laptop to the port OTG.
              You do not need any additional power supply, do not forget to hook up the TV HDMI
                Thanks, it worked!
                  Does the 4.2.2 one fix the video playback issues?!
                  I have firmware:
                  password darek1975
                  PS.
                  I have the exact same one as you, the MK809iv. As it's so new there doesn't seem to be much support or work being done with it. I'm very surprised that it doesn't even play standard definition video without the judder! So does the 4.2.2 rom you have posted the link for above fix the video playback issues?! If so which definitions does it work with?
                  Many thanks
                  Dan
                    As you may have problems playing films on a quad-core processor?
                      I have a mk809iv too. Anyone got a link for a ROM?
                        Hi
                        I have firmware:
                        password darek1975
                        PS.
                        Hi there, can i just confirm 4.1.1 rom works on mk802iv before i flash it. I am new to this and havent
                        flashed any roms till date as i am scared of bricking it.
                        please advise..only problem i have with 4.2 is it doesnt work well with flash player . so i am trying to
                        downgrade to 4.1
                        thank you
                          mk809iv roms please reupload
                          sorry for disturb, but your hotfile links to mk809iv rom isnt working due to hotfile closed. can someone with "good heart" please upload again this files on new server ? thanks and sorry to disturb you but looks like youre the only one in all web to own this files.
                          hi
                          alex
                            send mail PM
                              KitKat
                              Hello
                              I saw a video from ApadTV in wich they are testing the mk809 IV but with a 4.4.2 kitkat rom...
                              Has anyone this rom or does somebody use a stick with that rom?
                              Perhaps does it solve few problems of the 809 IV?
                              Demoon :-)
                                Originally posted by Demoon View Post
                                Hello
                                Demoon :-)
                                I flashed a kit Kat rom and it worked, but I had stability issues with Xbmc, and the ir remote did not work. Ultimately I flashed back to the stock rom, and have been trying to solve the frameskip, juttering, or whatever is going on. I can't play a video in Xbmc (beyond Xbmc and regular frodo/Gotham) without jerky and stuttering video. It's really frustrating. I used a perl script to modify the kernel with the frameskip modification. I flashed that kernel and it didn't change anything. I've tried flashing several other kernels but have not gotten them to work (stick doesn't boot).
                                I'm not giving up, I'll keep trying and post if I come up with a solution.
