ROM for the new MK809IV Quadcore??
Originally posted by aw_309 View Posthttp://www.aliexpress.com/item/New-T...821674807.html
Im intrested to buy this new version but i think we have to have the FINLESS ROM for this! = )
Is this possible to make? = )
REGARDS!
AndersCurrently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
Originally posted by ididmytime View PostThey are still using the mali 400 GPU? The CPU's are powerful enough as they are, it's the GPU which is the problem, having two extra cores isn't going to do a whole lot more.
As for making a ROM.... sheesh man... I want to right away but I need a device to work with! As of yet Geekbuying has not been able to send me one
I am glad you are back,BOB,I don't want to disturb you since you have your family thing to handle, the rk3188 device is packed for you and ready for ship,
we will make sure bob have all quad core tv stick and make great roms!
Originally posted by Finless View PostI was honestly surprised at this myself as well! I bet we still see only 720P stock kernels because of this.
BobLooking for developers
The Tronsmart T428 has:
CPU: Rockchip RK3188 quad core Cortex A9 @ 1.8Ghz max
GPU: Mali-400MP4 GPU
while the Tronsmart MK908 has:
CPU: Cortex A9 Rk3188 Quad Core,
GPU: Quad Core Mali 400;
as you can see from the highlighted text the tronsmart T428 has the mali400mp4 which has more power than the mali400 and for the difference in price is just 10$. So is it better to go for the Tronsmart T428?Last edited by neoal; 24 April 2013, 07:42.FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-mod
The MP4 is just an overclocked 400. The Mali should be able to hit around 500mhz, while the 400MP4 usually comes in a little over that. Considering most of these devices are under clocked, I would wait until someone confirms what speed these are actually running at.Currently Using:
Retired Devices:
Hi you probably do not know the topology of processors.
Do you buy MK 908 or other processor RK3188 graphics card will continue to MP4 (clock speed to 600Mhz),the same processor RK 3066 is the graphics MP4(clock speed 250Mhz).
No matter whether you will have a name MK 908 or T428
There is no separate graphics
UnderstendLast edited by darekmarta1975; 10 May 2013, 16:19.MY MINI PC: C4,CS918,M8,M8C
MK 809 IV Firmware
I have firmware:
Android 4.1.1 https://hotfile.com/dl/225374476/557...4.1.1.rar.html
Android 4.2.2 https://hotfile.com/dl/224829641/82f...4.2.2.rar.html
password darek1975
PS.
Android 4.1.1 does not work on SKYPE webcam Logitech(antutu 14000)
Android 4.2.2 is faster and more stable(antutu 15400) also works every version of XBMC,but the problem with SKYPELast edited by darekmarta1975; 05 June 2013, 11:48.MY MINI PC: C4,CS918,M8,M8C
Darek, thanks a million for these links. I was going out of my mind with my MK802IV on 4.2.2. On a whim, (albeit, unsure about the outcome) I figured since it's the same hardware, I would flash the 809III 4.1.1 rom, and now my 802IV is usable again. I even put the antenna back inside the case, since the only way I could get a signal was with the mod. Now I don't need the mod to get great wifi. Hoping to get an updated rom for my version, but just wanted to give a HUGE thanks for uploading and sharing the files.
Source: http://en.wikipedia.org/wiki/Rockchip#RK31xx_series
Originally posted by BrunoNRG View PostCorrect me if I'm wrong, but don't all android tv players that have the RK3188
quad core processor have the same GPU (Mali-400 MP quad core 600 MHz)?
The difference is only in the timing graphics and can be from 450-600 MHz.
The standard of what is realizes it is set to 450 MHz, but can be overclocked to 600 MHz of course if you have a heat sink on the processor
Once again the processor is integrated with graphics. And no matter whether it will be UG, MK or any other invention
Originally posted by darekmarta1975 View PostAll have the same RK3188 the graphics.
There are currently 1817 users online. 1 members and 1816 guests.
