NOW: The good part of the post comes:
i didnt want to lose my settings and apps and do a full rom flash so i thought of experimenting and well it went good. what i did was this:
1. Restarted many times the device by pluging, unpluging the power (no luck with that)
2. I connected to the pc with the otg port and i flashed the recovery-cwm.img file and rebooted (still no luck)
3. Reconnected to pc and flashed the boot.img and rebooted (still no luck with that)
4. Reconnected to pc and flashed the misc-boot-recovery.img and rebooted into cwm menu.
5. i wiped the cache partition and then the dalvik cache and then i did a fix permission and rebooted
After 1 minute the stars on the boot screen started to go on and off and then after 30 seconds i was on the lockscreen of my mk808b with the system as it was before.
