Cube Talk T7 RileyROM 1.1
    I'm afraid I'm not able to make a kernel. First, I've never done a kernel....much less for an MTK device. I currently don't know of any developers on FT doing MTK kernels right not...except for maybe Abdul_pt.
    Randy
      Thanks any way.
        Originally posted by Taajan
        I've been able to port a a rom to our phone. It's from the V919 3G tablet. I'll post more when Im done. Also, was not able to get the Lollipop to work.
        Sent from my V919 4G Air Core8 using Tapatalk
        Cool! Let us know how it goes. Thanks!
        Currently, I'm running rooted stock 1.7 FW with 4GB internal app partition. Lollipop skinned using exposed module 'Monster UI'. Quite happy with it.
          If you go to needrom.com I posted a fully rooted zip stock of the 1.7 Dolby edition
          Awesome mate! Keep up the good work...
          Sent from my T7 using Tapatalk
            Good
              Zip method of compression?try store only method...
                Hey guys I need some help, I need to know how to change
                The system partition size?
                what do you mean?
                change space for partition editing scatter file or adjust .img preallocated size for system...?little partition then what you wait or need extra space?
                  System size is not the problem i think ....if it was minor of stock simply have less available space for new system app if bigger you cant spflash it...i m working to t98 lollipop but only bootloop on teclast logo!!!
                    Hi Guys ,
                    my App "Secure Update Scanner" says that there is a Update for our Device see Picture (latest 5.0)
                    Does anyone know anything.
                      Hi
                      here once more,
                      hope it works now.
                      gefattern
                        I was able to pull a raw system.img of the ROM I did
                        Taajan, could you please post a working link to your latest 4.4.4 ROM (with increased system partition and root) please? All previous links are broken
                          Hi Tajjaan and all,
                          what about a Port of a Lenovo K3 Note Lollipop 5.1 Rom,this Phone has nearly the same Specs.I am not a Rom Porter
                          so maybe someone give it a Try.
                            I am thinking of buying one of these http://www.everbuying.net/product997417.html is there still any work going on for a custom rom or should I just stick with getting root access.
                              Hi Robynb1
                              if i was you i would buy another newer Device with better FW Support,T7 has only Fake Yun OS no orginal Kit Kat 4.4.4.
                              Root is no Problem,but Cube makes no Updates for this Device & Custom Roms nearly not exist.It is 64bit but only 32bit FW.
                              Even Riley makes nothing new and he is a Owner of a T7.I have my T7 longer than a Year,so i would not buy it again.
                              The Gpu is not so strong only 720 MP2,the CPU only uses 2 Cores most Time with max 1859mhz and that's only the little Core.
                              I hope it helps
                              nice Day
                              gefattern
                                Hi Riley & all
                                i was able to boot your 1.1 Rom,i took another boot.img.I think you want to know,that it works.I can upload if you want,maybe this helps to bring this Thread back to live.
                                later more
                                nice Day
                                gefattern
