NEW Official 004 firmware NEO X8, X8 PLUS, X8-H
Great news, nice to see my device keep updating
from MinixForum:
Major change log (since 20150207 firmware):
1.) Fixed various app compatibility issues
2.) Improved auto refresh rate switching compatibility (mainly for online contents)
3.) Added Google+ support
4.) Improved amplifier compatibility
5.) Added support for Vidon XBMC/Kodi (for technical questions regarding Vidon XBMC, please contact them directly, we don't answer questions related to this software since we don't make it and we don't know much about it)
6.) Fixed MX player playback crash issue
7.) Hebrew language UI bug fix
8.) Fixed HDMI-CEC long press freezing bug (on some TVs)
9.) Fixed mouse movement doesn't exit screensaver issue
10.) Fixed XBMC/Kodi wakeup bug
11.) Fixed AML remote control failed to connect issue
12.) Fixed MX player subtitle duplicating issue
13.) Fixed when muted the UI key movement still have sound issue
14.) Fixed HDMI-CEC multi devices issues
Plus many other minor fixes!
for me, important are HDMI-CEC fixes, wakeup, etc...
regards!
Originally posted by rpgmaker View PostIf my device is rooted can I still update using FOTA without issues?
I updated mine fine (rooted v3) via the fota update. Afterwards OTAUpgrade.apk is missing from the v4 update - so if you want to root easily, save this file first or extract it from the v3 firmware (zip is posted on this site), then install it onto your minix neo x8h and run it to install the root update (also found on this site). Then you'll have a rooted v4 firmware.
Originally posted by mrdude View Post... Afterwards OTAUpgrade.apk is missing from the v4 update - so if you want to root easily, save this file first or extract it from the v3 firmware (zip is posted on this site), then install it onto your minix neo x8h and run it to install the root update (also found on this site)...
and I think the apk is the same so you can also use the download...
RK3288 Devices
- Overview BOX (LINK !)
No, Finless isn't gone
But he is really busy at the moment... that's why you don't hear anything from him at the moment.
But I have to say, at MINIX meanwhile a custom rom is at best case something like a nice to have but not, as at other cheaper Chinese devices, something like a MUST to have, because they have a really good support and also understand to porting parts of Finless mods to there stock roms...
RK3288 Devices
Thanks for all you do Finless !!!
There are currently 4753 users online. 1 members and 4752 guests.
