I have a box here with my own personal settings, favs, addons, etc. I backed up the .org.xbmc.kodi folder and all of it's contents to my USB.
I have another box here (same model) with add ons and settings pre configured. I deleted the entire .org.xbmc.kodi and copied the export from my other box and imported it. I loaded Kodi, works fine with all my add ons and favorites.
My question is for long term use or any for that matter, was my methods of copying over the data harmful or could be harmful in any way? Are there system specific files or settings which should not be deleted from the system I copied data from which was copied from my old box and could potentially mess things up? I just want to know if my methods will screw anything up in the future and ensure stability on the box.
Thanks everyone
