Any Windows or Ubuntu rom for the MK808B Plus?
I'm working on porting this right now. It's booting but I'm running into issues wireless and Bluetooth. Also my keyboard sometimes stops responding at the login screen. It's coming but it's just tough work
Originally posted by noderat View PostI'm working on porting this right now. It's booting but I'm running into issues wireless and Bluetooth. Also my keyboard sometimes stops responding at the login screen. It's coming but it's just tough work
Go nordat
Originally posted by Breadboard View Post
I just registered here to thank you for your work and to motivate you to keep going.
Go nordat
Thanks! I've got arch linux booting at the moment with ethernet support. I'd release it but I think without wifi or a GUI it'd be pretty useless for most users here
I would definitely use it so if it's ready to go (I don't need wifi or GUI) can I try it out?
Thanks! I've got arch linux booting at the moment with ethernet support. I'd release it but I think without wifi or a GUI it'd be pretty useless for most users herePrahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Sound promising! Could you share how you set it up with Arch Linux?
I've been trying to get the MK908ii (RK3188 Processor) to run a kernel > 3.0 for the past year and have given up. I need kernel > 3.8 to work with my USB device I'm building (FTDI chipset). The MK808B+ has the same form factor as the MK908 and would work great as a micro server for a bunch of maker projects where size is critical. If I can't make the wifi/bt work, I'd add a wifi USB dongle.
I'd be happy to help/test if you push to onto GitHub or the like.
Do keep up the great work!
Best
There are currently 5140 users online. 3 members and 5137 guests.
