Power off from menu still reboots box.
M8 5.0.8
Originally posted by al8782 View PostThis is an actual M8 build that truly has all 4 cores working. It originally had no sound , but I contacted Kerber and donated to see if he could fix it and he did. This build flies.
http://amlinux.ru/target/
Audio works fine for me. Have tested audio through receiver and optical and both worked fine also. I've done both tar file and flash with zip. Flashing from zip is what I've seen suggested with OpenELEC builds. And a buddy of mine said he notices the box being more responsive when flashing. I audio output settings are set to default analog and with default analog optical worked also.
Originally posted by node View PostI did from zip still no luck. Audio settings the same. Did you go back to stock first then reinstall, or you stayed on Openelec and go straight to Kerber built?
Thanks a mil, things I notice, I can see only info for two core but I am sure all four are running, as I see the CPU use as 3% usage tops, whereas with codesnake built, I see like 30% usage, working much harder. The other thing I will like to fix on the box is the resolution how can I get 1080p I can only get 720p. Nothing to do with the this built, but from the start, does not matter what monitor I attached to the box.
I run M8 2gb+8gb box. I load the Openelec you pointed me to, and got Kodi 14.2. I have never seem 1080p nothing always 720p. From stock I load Codesnake 5.0.3 then upgrade to 5.0.8 the resolution is always grayed out, and is showing [email protected]
As for the core can only see information for two the third one I cannot see any info, then the information band with the % use.
You're using the M8 buikd from May 4th? I can see all four cores working nothing is greyed out in video output or audio output. I can choose between 1080 or 720. Maybe it's the 5.0.3 that's causing the problems, I'm not sure. Like I mentioned before I could use 5.0.3 at all on my Q box. I would load a different build first. Load megatrons build and then 5.0.8. I've done this before with one of codes builds because I was getting the M8 overlay problem on one of my tv's.
Originally posted by node View PostYes I am on M8 built from May 4th. I want to think this myself, that the 5.0.3 had something to do with it, causing the resolution to stay fix at 1280 x 720p and not be able to see the cores.
Hi al8782. I have flashed on my square M8 the above ROM. All Dolby Digital video files play fine, but from the rest of the video file (ie. aac audio codecs) i do not get any audio. Any thoughts?
SOLVED - After playing with my audio settings i discovered that i had to select the "Stereo upmix".
Thanks for the great work. This is the best openelec version that i have flashed to my M8.Last edited by kakoskm; 12 May 2015, 17:59.
There are currently 1555 users online. 2 members and 1553 guests.
