M8 5.0.8
Originally posted by burt35 View Post
great i'll give that a try cheers.
I believe, this issue has nothing to do with this built, but has to do with the original firmware that is written to the box from stock. I wrote a firmware on one of my M8 (this I cannot remember what firmware it was, but on this M8 and this M8 only I am able to change the resolution with this built). If only I can remember which firmware it was.
Originally posted by hycel View Post
JustME any more detailed instructions you can give me? where do i put that code? into a file? and place it where? Thanks "ifconfig eth0 down; ifconfig eth0 hw ether 00:23:47:97:E5; ifconfig eth0 up"
Bugs are Sons of Glitches!
JustMe
just a quick question when you install this on your boxes do you have it connected to a 1080p tv and how do you install it is it via recovery update zip or extracted contents to memory card? my box is working fine except the 1080p greyed out still! I have installed this through memory card extracted zip and using my pc monitor to install not sure if this makes a difference.
I do the initial install on one of my 1080p 24" PC monitors and then I bring it downstairs for final testing and to demo for clients on a 65" LED it initially is set to 720p and I do not have any issues changing it over to 1080p if needed.
Originally posted by al8782 View PostOpenELEC is defaulted to 720p when I install it and I can change it to 1080p or 1080i. Also on my M8. I got my M8 last year. And have installed a few didn't roms on it. Just can't remeber which android roms I installed. But I pretty much installed all the different OpenELEC builds.
Originally posted by al8782 View PostI forward this thread to someone and he tried to update his M8 box. But he said after he updated the box with the .tar file his box won't turn on. The blue diamond just blinks. He also can't get into recovery. I've never came across this before. Anyone had this problem before..
Guys,
My M8 2GB works like a charm on 1080p, but after some initial hickups:
I first started by installing (Toothpick) and used the REGULAR install file, I think the UPDATE zip is for updating an earler Openelec installation!
My former installatio software was I think Justme 1.6 or 1.5... I do nt remember.
Software started perfectly, but on 1280p.
My M8 is connected via HDMI to an Onkyo receiver allowing all kinds of resolutions up to 1080p/1080i
I could change the resolution.
But after restart it reverted back to 1280 again... hmmm:
I learned that If Openelec does NOT see the correct resolution from the screen it either a) reverts back to standard (1280) or b) chooses the resolution that the screen is on at that time..
So I changed my Onkyo receiver NOT to pass through HDMI but set it fixed to 1080P. I also made sure that my TV is set fixed to 1080P, so the whole chain is reporting back 1080P to Openelec.
I choose 1080P 50Hz (in my case) again in OE, under systems settings
Now: it is great, even after restart it comes back to 1080p
For what it's wordth: I pass Through audio via optical out, and do NOT use Audio over HDMI.
Hey guys. I'm thinking of buying this box after I move. If I get this box, would the OpenELEC files used on the M8 be the same files I would flash to this unit? If not, could you direct me to which files to use?
http://www.****.com/itm/Beelink-M7B-...item43d91fe9a6
There are currently 1789 users online. 0 members and 1789 guests.
