All thanks to media.amplayer.widevineenable = true
TIPS for S802 (and others) Owners (MXIII 2GB)
Originally posted by dave_999 View PostWow, thanks. I now have all of the UK catchup apps fully working: BBC iPlayer, ITV player, 4 Catchup, 5 on demand.
IOriginally posted by dave_999 View PostWow, thanks. I now have all of the UK catchup apps fully working: BBC iPlayer, ITV player, 4 Catchup, 5 on demand.
ontwofronts : You simply need to edit the 'build.prop' file and change media.amplayer.widevineenable from 'false' to 'true'.
I'll leave it to you to google how to edit your build.prop, you can either do it with a root file explorer app: ES File Explorer or you can download a build.prop editor app from google play which may be easier for you as they normally allow you to backup the file too just in case you make a mess of it.
Originally posted by dave_999 View Postontwofronts : You simply need to edit the 'build.prop' file and change media.amplayer.widevineenable from 'false' to 'true'.
Set that up and, then use WinSCP, to log into the SFTP (Explorer), and edit it with something like Notepad++.
These are great tips. Does anyone know how to flash TWRP on the MXiii Amlogic s802. The 2 gig version. Nothing I do will get the MXiii to recognize the TWRP recovery image on the sdcard or usb thumb drive. I have tried everything I know. Even Flashify, Rashr, TWRP Manager. The stock recovery just won't see any image files. Even tried the adb shell method but got a write permissions error.
any help would be very appreciated
There are currently 1952 users online. 4 members and 1948 guests.
