New MK808B Plus 110K4 firmware
here it is: http://chinagadgetsreviews.com/downl...-tv-stick.html
I'd love to have a dualboot so I can try this without throwing away my actuel setup.
Can anyone tell me how I can try this firmware on my device (m201 S805 MBOX based, Ditter U20)? The problem is that this device doesn't have a reset button (I opened it, so nothing for sure; also nothing inside the audio socket). I rooted my device, and backed up my firmware using the Tv110 TWRP recovery.zip - seems to have worked fine.
All the instructions I could find (with burner tools etc) are using the reset button. Is it possible to install this 110K4 firmware with just root and no reset button?
Can I just copy all the files from the 110K4 firmware (unzipped) to external sdcard, and run "reboot recovery"? I did that with TWRP recovery.zip, and it worked fine.
Or perhaps I should use the "Upgrade" option in MBOX settings? But I think I need an "update.zip".
Originally posted by Johnoo View Post110k Firmware, in XBMC KODI etc.. aspect ratio is displayed wrong when playing a video, Mp4, Mkv etc everything at fixed full screen 16:9. ... Avi works fine.
PM the Devs about this, a while back, but no reply.
I had same issue when I had Kodi v14.1. Problem was gone after updating to Kodi v14.2
There are currently 2500 users online. 3 members and 2497 guests.
