4gb/64gb VOYO Mini PC Windows 8.1 4K Media Player Intel Z3775 Quad Core
I am an idiot that bought this lol! Mostly because the z3775 has quick sync.
Biggest problem though, It overheats and turns off. Anyone know if adding a small heat sink will work? i have drilled small holes in the top lid and that helped some.
i now have installed windows 10 and followed instructions like in previous threads and i cant manage to get the HD graphics driver to install. shouldn't it be the same driver as the z3735 like in the previous model?
Anyone have some advice for me?
Maybe missing some other driver or windows is just confused.
http://freaktab.com/forum/tv-player-...rocessor/page2
Post #45 last to download should get you out of trouble, do the INF first the the driver update utility.
Heat: Sit it on a laptop cooler,
Adding heat sink on bottom cut whole so it will protrude a few mm, larger runner feet also.
Cheers
After much testing by installing all drivers posted for the mini pc i almost gave up but ended up trying to install the Voyo A1 tablet drivers and it worked like a charm!
I also found the reason why it was over heating. A guy at the assembly line must have put a layer of sticky ruber on both sides when it should only be on the top side so it covered the whole cpu cooling plate on the bottom so it worked as insulation. I cut away the rubber or whatever it is and it survived 1 hour of stress testing in prime 95 without problem.
I now love this little device. With z3775's quick sync it streams games through steam with great performance and Kodi runs just as fluid as on my workstation
There are currently 3211 users online. 0 members and 3211 guests.
