Advice on reinstalling Finless 1.1 TWRP Recovery missing?
Hi guy's I need some advice for some unknown reason I had the dreaded bootloop again.
I flashed to 109k4 then installed finless 1.1 from ext SD containing the recovery image and the ROM zip file. Using the reboot app I rebooted into recovery all I get is android recovery not TWRP that I need to recover my saved file on ext SD.
what am I doing wrong
Removing external SD as according to finless instructions rebooting to recovery I now see TWRP recovery menu. Inserting the ext SD with my previous backup on then back up from ext SD the file cannot be accessed? Should I relocate the file to the internal SD and whereabouts.
