I finally managed to make some videos of my troubles with the amlogic codec and xmbc. In fact, it affects the use or hardware decoding overall in the other players as well.
PLaying on an old analog tv,
both xbmc oman's 13.4.0 and kodi 14.2
Firmware 112k4.
On Oman's it crashes the box on first run.
On Kodi, it oversizes the image with amlogic codec on. If I turn it off, the image fills the screen and properly displays.
I have this problem since I updated the box after purchase. Check it out.
https://www.youtube.com/watch?featur...&v=Y_wccM-ZrzE
https://www.youtube.com/watch?featur...&v=yR8ZDISm0po
https://www.youtube.com/watch?featur...&v=i1oSOr3orJw
xbmc-13.1-Gotham-4K-video-2160P-output.apk from stane1983 works but if I jump from media to media it goes back to the oversize problem. Only closing the video entirely I'm able to play another with everything in the screen (not oversized/zoomed). Also, I couldn't connect to the media databases to update content info.
I set permissions on superuser for xbmc too.
What is wrong with it?
