MK808B PLUS Android&Ubuntu hybrid ROM
Originally posted by qaz2 View Postmk808b plus ubuntu wifi does not work, does not work eternet usb usb, usb not working I wanted to ask if you solve these errors
thanks
Wifi works without problems.
USB host & USB OTG works without problems, tested with:
wireless keyboard/mouse
USB Flash drive
USB HD
USB to serial adapter
I don't have USB ethernet adapter, so it is not tested.
thanks
And first of all, thx for ur great job !!!
I achieved the installation. And everything is ok, except network in unbuntu : i can't surf and can't do updates or download software.
Wifi is ok on android.
How can i fix it ?
Thanx for ur answer
What can be the reason when i cannot go into recovery mode.
I tried 4 different 8GB SD cards. It doesnot work.
Is it correct to put a pin into the left hole (klick) and then plug in.
How should the sd card formated, fat32, extfat, ntfs?
thank you for your reply
SOLVED: SD Card must be formated with 2048 not standardLast edited by hochgattererjohann; 26 August 2015, 17:44.
Hey loboris,
This is a pretty cool project; thanks for your work.
I'm very interested in how you created this. I have a Minix X8-H Plus (amlogic s812-h) and I'd like to see if I can get something similar running on that, but I am hard-pressed to find any information about running Linux on s812 devices. I found an OpenELEC image at one point that worked, but that and this are the closest resources I have found so far.
I imagine you get great performance by writing to the framebuffer directly, which appears rather novel from within Android. What exactly is the limitation for hardware video acceleration? By running through the Android kernel, you'd be using Android's graphics driver, right? I'll admit I don't know too much about drivers in Android/Linux. Perhaps you are referring to hardware video decoding? How might one approach improving this?
Cheers,
-ZimbiX
@ZimbiX hardware GPU acceleration in Ubuntu is not possible, Ubuntu only uses framebuffer.
Booting Ubuntu on MK808B+ is now possible. Download from linuxminipc, see this for more info.
It sounds nice, but neither your Debian8 nor your Ubuntu Mate 15.04 are stable. I copied a lot of files (about 7000 and about 32 GB) from an USB-Stick to a Hard Disk and suddenly after 40% done, the system was frozen. This happened both in Ubuntu and in Debian. And also the system freezed during writing a post in this forum.
So your linux versions are not really usable, except for experimental purposes.
The Android for MK808B plus also works stable. Filesystems NTFS an EXT4 were handled correctly. And copying 32 GB fom one USB Sick to a Harddisk was done nearly twice as fast as in Linux and it didn't freeze.
I have an old picuntu, derived from an Ubuntu 12.10, which works fine on a MK808B (no plus), but the packages are not maintained any more - so firefox is too old and crashes sometimes for some websites (but not the ubuntu system).
I am looking for a better and more up to date solution than the old picuntu on the old MK808B. But seemingly no stable solution does exist.Last edited by mittelalf; 10 September 2016, 21:06.
There are currently 2562 users online. 0 members and 2562 guests.
