HPH LP v0.9 Beta by mo123
    Firmware is based on Lollipop 5.1.1
    Working
    - HDMI sound
    - Ethernet
    - Wifi
    - Bluetooth
    - Rooted
    - Color Improvements
    - 4 GB App Space, apps can install correctly including SPMC/Kodi
    - Status bar
    - No Flickering
    - Youtube, ES File Manager, Chrome Browser
    Not working
    - TV Out
    - Remote
    - Still some other bugs
    If you get a blank screen on first boot
    Connect device to TV then disconnect power cord to device, reconnect now it will work correctly.
    Overall firmware works very well.
    Load firmware with second tab in flash tool and then Upgrade.
    Download Link: Here
    you say remote not working.... how do you control then ?
      Airmouse, USB Keyboard, USB Mouse, Bluetooth mouse
        Download Link: Here
        Thanks for the link.
        Feature list says much indeed, but is it ok for everyday use (browsing, youtube, movies, games)?
        If yes, I might try it and hopefully leave it installed, regardless of being a beta.
          If you use eg. wifi and an airmouse it works great.
          Web Browsing, Media Playback, Kodi, Gaming all work great.
          TV Out(90% don't use it since it's connected to an HDTV) and LED light not working, IR Remote not working(if you use a TV Box an airmouse is a must and a great thing to have)
          At the end of June there should be official LP firmware.
          This is just for people to test out in the meantime, but can be used as your working OS since there are only small things still to be improved or fixed.
            Can this beta be flashed the same way as v1.6 via recovery?
            I'll probably loose all of my data this way, right? Especialy because of an entirely different build?
            I don't have time to set up my system all over again, so I might wait end of June afterall for a final version.
              Lollipop Recovery is different than KitKat Recovery. more partitions so it won't work.
              You can also flash TWRP Lollipop Recovery but I haven't tried that yet.
              You can then make backups and restore it with TWRP.
              Since apps now also use ART, I think restoring KitKat backups that use dalvik won't work well.
              Official firmware will be released in the next few days.
                May want to try this; http://crewrktablets.arctablet.com/?p=5336. On vacation Firefly at home, now I can't wait to get back home.
                later---cappybob
                  Hi mo123 can add Kernels for (AP6330 Wireless chipset) i tested on my cs928 rom runing work my score antutu 37717 , on tv box back usb not work otg usb not work.
                    Plus 1 - would be good to have on ap6330 chipsets.
                      Try swapping files in /system/etc/firmware
                      Es File Manager, enable root explorer and hidden files
                      ANDROID_FW_PATH, "fw_RK903_ag.bin"); ANDROID_FW_PATH, "nvram_AP6330.txt"); to
                      ANDROID_FW_PATH, "fw_bcm4339a0_ag.bin"); ANDROID_FW_PATH, "nvram_AP6335.txt");
                      to trick the system into loading your AP6330 drivers which it thinks is AP6335
                      I can make a kernel but would wait until final Lollipop is released next week.
                        That would be great Moe123. Alot of other devices use that chipset so would love to see kernel with it. Question for you. Unpacking lollipop roms I know how to do it in kitkat with tools how does it work in lollipop the same??
                          The same as for Kitkat firmware.
                          You can unpack in Windows or Linux.
                            Very good works well on the mk902ii with exception of dead usb ports ect and no side launching needed love that. Great work moe123
                              Mo, I'm in the minority which often uses the TV-out, due to watching on my R89 in my bedroom where my TV is SD and has no HDMI (The baby would go into withdrawals without constant access to Mickey Mouse clubhouse!).
                              Wasser has TV out but no wifi (and some other stuff), you have the other stuff. Any chance you guys could collaborate a little and get a more functional ROM going?
                              Thanks for all your hard work!!
                              Cheers!
                              -SB
                              Currently using U-BOX R89 with mo123 v1.6.
                              Other android tv device - ADT-1 running latest PureNexus 6.0.1 MM and very impressed with the changes vs stock molly!
                              Pipo M9S -- CrewRKTab custom rooted 4.4.2
                              RCA Viking Pro 10 -- Custom stock rooted 5.1 by me <- FOR SALE
                              ----------- ROM by me, the first way to update ZTE Force 4G from ICS to JB http://androidforums.com/threads/fin...om-ics.886408/
