MXIII HELP
MXIII HELP
hello i was wondering if you can help me out i got mxiii 2g x8gb from china .... they came with a build KOT49H.20150516 test-keys i have been working on this for 3 days i wont let me update a new firmware ?? using the sd card toothpick methode ... weird where as my otherr mxiii i have had let me ... i was able to use the usb burning tool to update to 114k4 now the wifi wont work so i updated to 115k4 and still no wifi i opend the mxiiii and seen that it has a wifi chip ap 6324 ?? where as my other ones used ap 6330... im haveing some problems can you please help any suggestions possibleTags: None
Originally posted by Ichijoe View Post
MicroSD (USB) [Three File *.zip] :Here
Just upzip the Download.... Then copy those Three Files. One of which will also be in a *.zip File (Thats the actual Firmware File). along with the recovery.img and a *.aml File, to a MicroSD.
then enter recovery mode as you normally would.
so i did try that this week but still no wifi. so i ordered a tronsmart box and sent the other one back . the new box took openelec 5.0.8 everything works fine. thank for your time Ichijoe wish i could have figured it out . thanks so much to everyone here its a great site to read when your in need .
Originally posted by londonshore View Posthello i was wondering if you can help me out i got mxiii 2g x8gb from china .... they came with a build KOT49H.20150516 test-keys i have been working on this for 3 days i wont let me update a new firmware ?? using the sd card toothpick methode ... weird where as my otherr mxiii i have had let me ... i was able to use the usb burning tool to update to 114k4 now the wifi wont work so i updated to 115k4 and still no wifi i opend the mxiiii and seen that it has a wifi chip ap 6324 ?? where as my other ones used ap 6330... im haveing some problems can you please help any suggestions possible
originally. I can't boot to recovery on my box anymore. Can you point me towards a firmware I could flash via USB burning tool? I tried flashing many firmwares nothing worked, stuck at 2% or 4%. I saw your post and we have similar box with similar build.
Please help me... Can you point me towards a download link of a firmware for our box that i could try? Thank you...
There are currently 2433 users online. 0 members and 2433 guests.
