[ROM] RemiX 115k4 >>>s802
Originally posted by aeolous View PostI found out what was wrong with my LG shit TV my apologies it has a burned hdmi board actually not only the hdmi's but also the composite and scart don't have any signal
just my luck.Mk802IV Neomode 1.9a original rom 720p
Originally posted by Magnus33 View Post
Ouch that's a major pain sounds like a hardware fault rather then anything you could possiably have done.
First sorry for the offtopic yes it's a hardware fault talk on the phone with LG Greece and the mainboard have to be replaced in my LG LD750 and the cost is 170 euro + 23%vat + work in my question to them if it is logical a 5 year old tv that no longer worth 100-150 euros to have so expensive parts he told me that's our policy go figure, so if anyone knows where can i buy a mainboard for a 32'' LG LD750 in a affordable price new or used it would be great.
You can do a google search and likely find a replacement mainboard quite abit cheaper.
Have you looked at the board though since quite a lot of the time capacitors can blow and knock things out.
There easy to see when bad as then tent on top and thankfully they are very cheap to replace by yourself.Mk802IV Neomode 1.9a original rom 720p
I really like this ROM. Please keep the tronsmart alive a lil while longer. One issue i'm having is if I leave the Tronsmart S89 on for long periods or if I turn off the TV for a while and then turn it back on there will be no display. I have to unplug the box and turn it back on. I'n developer options I have it set to stay awake. Not sure why the display is cutting out.
Originally posted by pninJust curious: has anyone tried this Abdul_pt's RemiX 115k4 on a Beelink I One? (i826, 2G/16G Amlogic s812 based)
Not that tech savvy, so would like getting a few different reports before trying it myself...
Tapatalked
Originally posted by isham.padronI really like this ROM. Please keep the tronsmart alive a lil while longer. One issue i'm having is if I leave the Tronsmart S89 on for long periods or if I turn off the TV for a while and then turn it back on there will be no display. I have to unplug the box and turn it back on. I'n developer options I have it set to stay awake. Not sure why the display is cutting out.
Tapatalked
First post, registered to say thanks for the Firmware, REALLY appreciated!
I’ve been looking for a decent Android box to replace my PS3 as a media player, I am on my third now, none so far have came close to my standards / expectations.. I came close to me giving up and re-purposing an Raspberry Pi with OpenElec.....
I brought a MXiii 2/8 clone from Amazon and although it was close to being OK, it suffered from poor firmware, (tanwei@tanwei?!) , almost every app in the Play Store showed as being incompatible, weird locale & keyboard settings (kept reverting to China and Chinese input)... Wireless keypad would not always wake it from standby...And so on.....
Before sending this back I decided to try a couple of different firmwares to see if I could get a working solution...
The Finless ROM looked good but I could not get the update to take, it got stuck at the boot splash screen, it looks like the system partition got corrupted ?! I managed to fix this with TWRP and some shell wizardry (mkfs).....
This firmware took second time round, and so for I’m REALLY happy with it, it’s fixed all the issues I was seeing with the firmware that came with it, basically I’ve got a box that I now feel happy with, I will thank you again....
Couple of queries / comments.........
- If you update or release an improved version, would it be possible to include the permissions patches to get Kodi to play nice, specifically these:- http://freaktab.com/forum/tv-player-...15-2#post52511 I’ve installed Universal Init.d and set them that way but it would be nice not to have to...
- TWRP Manager does not seem to recognize the version installed, is there a reason for this ?
- When in Recovery, it says my bootloader version is unknown, is this normal ?
- Related to a) I noticed there were some init.d scripts already present, was this already incuded in your ROM ?
Thanks again,
Itsmeedoofer....
There are currently 1631 users online. 3 members and 1628 guests.
