[ROM] RemiX 115k4 >>>s802
Originally posted by abdul_pt View PostThis should work on S82/S82B/S82H/MXIII(1G&2G DDR) and S89/S89H
Based on 115k4 release from Trosmart, i made some changes much like my previous RemiX 114k4. This will not wipe your Data, and you can install on top of 115k4, of any other Rom that you have running without the need to wipe.
Changelog :- Remove OTA binaries and services.
- Remove some apps. File manager, OTA and others apps that can be acquire from Play Store.
- Added init.d support
- Added Nano text editor. Just type 'nano' from terminal window to open it.
- Added Bash environment. Type 'bash' in terminal window to enable it.
- Increase TCP buffers.
- Raised CPU clock to 1992. It was on 1608.
- There's a build.prop.nexus10 in system root, if you want to spoof your Box.
- Included some apps, they will be installed as user, so you can remove them if you wish.
- Included TWRP 2.8.7.0. This version backups internalSD.
Installation:
Like any other SDcard rom zip.
Download, and extract the zip to the root of your External SD.
Boot your device while pressing the reset switch.
Sit back and let it finish
--> RemiX 115k4
How did you increase clock speed?
Hello... first time poster here...
I have Minix X8-H and friend suggest me to flash this rom. Everything went fine and rom is flashed, but now it's stuck on boot screen. I flashed several rom's on my minix, but if something goes wrong I was able to enter recovery by hardware button (hole). Problem is that I can not boot into recovery. Needle in recovery hole dosent give me any signs of recovery booting and rom dosent boot even after 30 minutes.... tried like 200 times
So, did I fcuked it up really bad or there is hope to fix it somehow?
Thanks in advance for answer.
Edit: Tried following solutions
1. SD card clean install of Minix rom, dosent recognize minix recovery.
2. SD card with recovery from remix rom zip, recognize file but stuck at 1% or so... stuck on beginning of process.
3. Burningtool, after box get recognizes, started flashing IMG of minix rom, but stuck at 3%.
4. Tried TWRP, but it just load first screen and dont enter to recovery itself....
I am out of ideas.Last edited by DaPimp; 27 October 2015, 21:43.
Salut,
my currently bought mkiii 1G runs fine with 115k4, even wifi does (6xxxx chip).
The original Version 112k4 as well as the 115k4 has some outages: the os and/or the application sometimes stops responding for several seconds. Perhaps this is by design to suppport isochronos media streaming, perhaps it's the lightweight hardware or ... whatsoever, it's strange.
The reduced settings dialogs result in reduced usability of the device: seperate users, lockscreen etc. is needed for a family used multi media device. How to restore the full settings dialogs?
Even the Screen saver has to be replaced because of ist low level design. How?
All in all it runs (fine)! But it would be better with some minor extensions. BTW, an ASUS Nexus Player with Lollirock realy rocks! By hardware the mkiii should be able to compare to or supersede the ASUS.
ciao
Jens
There are currently 2724 users online. 0 members and 2724 guests.
