my S82B shows temperatures from around 70 degrees while listening to musik and over 80 degrees while watching video. App: CPU Temp.
1) Is it necessary or useful to change the heatsink or to build in a fan? For example with the ASRock heatsink on second picture. Its greater than the original one. I am not sure about the improvement. Or make the high temperatures no problem for devices life?
2) How can the original heatsink be detached from the chip? I dont know how it is fixed but i cant detach it with normal force.
Thanks for your help.
