Thanks Boxx. I'm Looking forward to the flashable zip with the 3 files that includes the Nexus 10 spoof.
Last firmware RKM (MK80_SDK3.0_150627.img) in tronsmart draco meta
Originally posted by Moulin1980 View PostHi Boxx, it is possible to have, flashable zip nexus 10 spoof ? thank you in advance.
this just spoofs a google nexus 10, nothing else changed.
Originally posted by Boxx View Post
I'm sorry, i didn't get it to work yet. They must have changed something in newer firmwares. There is no more script.bin and modifying the sunxi-ir.kl und build.prop does not fix the remote. I also tried to modify the sysconfig1.lhs but no luck. At the moment i have no clue what to do...
Remember, i own the mk80. So i did it the other way(installed latest tronsmart rom and tried to get the mk80 remote to work) but this shouldn't matter.
I have the 20150523 Beta for Draco AW80(Android 4.4) installed. I'll look for those files that you mentioned. Are they all located on the same folder? What is the location of the files?
Is it the MK80 that doesn't have the script.bin?
Also has anyone tried MK80_SDK3.0_150627_draco.img on the Tronsmart AW80 from this link? This image is supposed to fix the remote on the Tronsmart I believe. I'll have to test it till I get home.
Code:https://yadi.sk/d/9DGK8LF6hinYr
OK Boxx, a big thank you.
I have installed, the last TWRP for DRACOMETA of abdul_pt :
Link : http://www.freak-tab.de/abdul_pt/All...8.6.0_AW80.img
then, your Nexus 10 spoof.
All works perfectly.
**Edit**
Ok I just installed it. I used the MK80_SDK3.0_150627_draco.img file which is supposed to fix the remote and the only button that works on the Tronsmart remote that I can tell is the Mouse button which is volume up lol.
I have Mygica KR-301 remote and that one works fine though. It's a 2.4Ghz wireless Mouse/Keyboard remote. However the power button does not work arrrg,
Originally posted by Moulin1980 View Postwith last youtube V 1.0.5.5 ( bug little ).
The video in 1080P 60 fps, a little stutter, but it is the best result I've had with this resolution.
But maybe this is my internet speed is low ( Download is max 20 Mbps or +/- 1,9 Mo/s ).
We must be more, to do the tests, 1 notice is not enough.
Boxx do you know how to extract Tronsmart *.img Rom files?
I was able to extract the MyGica *.img Rom files with 7-zip but this is not working for these *.img files. I want to extract an older firmware that should have the script.bin to see if it works.
Yes, i know how to unpack and repack firmware images.
I already put a script.bin in place but that does not work.
At least a part of the remote config must be handled somewhere else now. You wont see a script.bin in the extracted image anyway, it is generated on install. you say 1 button works,my remote is absolutely dead and none of the files do a thing. try the attached zip and see if it changes anything. flash it with twrp. it puts all 3 files in place.
Attached FilesLast edited by Boxx; 08 July 2015, 05:48.
lhsOriginally posted by Boxx View PostYes, i know how to unpack and repack firmware images.
section and replacing it with the one for the Tronsmart Firmware.
I'll let you know if it works shortly
****Edit****
I changed thisCode:;---------------------------------------------------------------------------------- ;ir rx --- infra remote configuration ;---------------------------------------------------------------------------------- [s_cir0] ir_used = 1 ir_rx = port:PL06<3><1><default><default> ir_power_key_code = 0x5d ir_addr_code = 0xef10 ;ir_power_key_code = 0x18 ;ir_addr_code = 0xef10 ir_power_key_code0 = 0x5d ir_addr_code0 = 0xef10 ir_power_key_code1 = 0x5d ir_addr_code1 = 0x7F80 ir_power_key_code2 = 0x5d ir_addr_code2 = 0x7F80 ir_power_key_code3 = 0x5d ir_addr_code3 = 0x7F80 ir_power_key_code4 = 0x5d ir_addr_code4 = 0x7F80 ir_power_key_code5 = 0x5d ir_addr_code5 = 0x7F80 ir_power_key_code6 = 0x5d ir_addr_code6 = 0x9F00 ir_power_key_code7 = 0x5d ir_addr_code7 = 0x9F00 [pmu_key] pmu_key_poweron = 0
Code:;ir rx --- infra remote configuration ;---------------------------------------------------------------------------------- [s_cir0] ir_used = 1 ir_rx = port:PL06<3><1><default><default> ir_power_key_code = 0x18 ir_addr_code = 0xff00 ;ir_power_key_code = 0x18 ;ir_addr_code = 0xff00 ir_power_key_code0 = 0x18 ir_addr_code0 = 0xff00 ir_power_key_code1 = 0x18 ir_addr_code1 = 0x7F80 ir_power_key_code2 = 0x18 ir_addr_code2 = 0x7F80 ir_power_key_code3 = 0x18 ir_addr_code3 = 0x7F80 ir_power_key_code4 = 0x18 ir_addr_code4 = 0x7F80 ir_power_key_code5 = 0x18 ir_addr_code5 = 0x7F80 ir_power_key_code6 = 0x18 ir_addr_code6 = 0x9F00 ir_power_key_code7 = 0x18 ir_addr_code7 = 0x9F00 [pmu_key] pmu_key_poweron = 0
I also made the changes to the build.prop for the mouse and this is what I get. The Mouse button is volume up, the down arrow is down and the OK button is up.
That is all that works and of course 2 of the keys are mapped incorrectly.
*****Edit 2*****
I used your sunxi-ir.kl only with my modified ROM and the power button works. I can turn on the box with the Tronsmart Remote now. However the only other keys that works is the OK button and is mapped to the down arrow and the mouse button which is mapped to volume up still.
At least now I can use the other remote to control the box and Tronsmart Remote to turn it on if I the box is off.Last edited by saulin; 08 July 2015, 06:37.
I have left my Draco for some months sleeping, because of too much bugs in the firmwares. It seems the Allwinner guys need very long to create useful sources, but finally the Rikomagic firmware is a good start for me. The Remix firmware of Tronsmart would not be bad, if it could learn to handle my logitech keyboard. My guess is, there something wrong with the usb driver. No google apps is not nice, but maybe there will be the option to install google apps.
The firmware from June from Rikomagic is very fast and stable, my logitech k400r works now good and my BT Philips headphone sound much more expensive with the some help of the equalizer of the vlc player - awesome and I'mreally not a fan of bt audio. Regular I use AKG studio headphones.
Kodi works stable without sudden step out like some other firmware before.
The only big issue I found so far. It looks like Rikomagic has locked the kernel to 720p and antutu says: this firmware could be a fake Rom(timer manipulation). Anyway it is fast for sure.
JD
Originally posted by frhdt007 View Post
Does it work with Tronsmart remote ?Originally posted by saulin View PostDoes anyone know which file we need to transfer from the Tronsmart firmware to this firmware and where to put it make the Tronsmart remote work perfect on this firmware?Originally posted by JDfense View PostAnd I forgot, the remote control does not work, so this is maybe a hardware difference.
JD
i have made a new thread so that people can find it easily.
please visit: http://freaktab.com/forum/tv-player-...o-remote-fixedLast edited by Boxx; 09 July 2015, 21:23.
There are currently 3150 users online. 3 members and 3147 guests.
