Since Finless 1.1 is the best firmware for MK808B Plus, we decided to give you this ROM which is nothing more that Finless 1.1 for both MK808B Plus and NEW MK808B Plus (with AP6212 wifi chipset). It was quite a lot of work but we think you will be happy to see your favorite ROM coming back on MK808B PLUS.
Everything runs fine (wifi, ethernet, bluetooth), just as the Finless 1.1 ROM did. We enabled widevine and added some files, so any feedback would be appreciate.
Moreover, we just put the original launcher and some very usefull apps like ES File Explorer, Aptoide and Youtube. Kodi 14.1 which comes from 111k4 is also preinstalled.
THE LINK (MEGA) : FINLESS 1.1 FOR NEW MK808B PLUS BY DROID-TV
INSTALLATION :
1- Put every files on your SD Card
METHOD 1:
2- Use "Update&Backup" app to "Select" the update, "Update" and "Validate".
3- Your MK808B PLUS will reboot and begin the update.
METHOD 2:
2- Put your SD card in the MK808B Plus and use the toothpick method to automatically launch it.
ENJOY !
