Android TV for MK808B Plus!!! (With working ScreenCast)
Not for now.
I will upload it today but have in mind that i didnt have time to work on it now.
Maby will update it later.Everything is possible if we work together!
Nope sorry,
Format data is hardcoded in updater script.Everything is possible if we work together!
First post updatedEverything is possible if we work together!
Quick update, I was running Kszaq's 5.95.3 build with Kodi 15.0 final (official OpenELEC 5.95.3 is with 15.0-rc2) on my MK808B Plus, and I must say it is a very good port of OpenELEC. I just wanted to try this rom. I downloaded your rom and extracted to my desktop of Windows 7 64 bit using 7zip program. I reformated a 32 meg class 10 microSD card with fat32, then copied the 4 files that were in the zip file to that SD card. I inserted the SD card into my MK808B Plus, removed the power from my MK808B Plus, inserted a small paper clip into the reset hole until I could feel/hear the click. As I held the paper clip still depressing the reset button, I reinserted the power plug. After about a minute, it started to install the Android TV rom. Right now it is at the welcome screen, ready for me to start testing.........
After a few hours of testing, Netflix will work, but have to side load it, also it still only plays in DVD quality. Kodi locks up whenever a video is selected to play, tried with the latest Kodi 15 and the latest SPMC, both have same problem of locking up, have to pull power on stick to reboot it.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Will look into that,
From what source are you trying to play video?Everything is possible if we work together!
Also, the calendar and contacts sync, which is great. I think this will be an awesome rom when the Kodi is working.
thanks.
I opened a MKV video from my NAS, via Ethernet using ESfile explorer and played it using MX player pro. The video played well, but not sound. I tried different audio settings in MX player, but nothing worked to get sound.
I did however open another app, HDHomeRun View app to play live TV streams in mpeg2 ts format and the TV streams played fine with sound.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
There are currently 2590 users online. 0 members and 2590 guests.
