Android TV for MK808B Plus!!! (With working ScreenCast)
Guys i will look into all the issues you reported when i have more time.
I should be able to fix most of them.Everything is possible if we work together!
Originally posted by lewy20041 View PostGuys i will look into all the issues you reported when i have more time.
thanksMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by elmasvital View PostFirst good work. Thanks by your effort
I have a problem with this compilation, really with all the compillation except openelec... the HDMI CEC stop working while pass some time, 30 seconds to 2 minutes.
Glad OpenElec worked for you. only rom that works with my Bravia is the newest official 111k4 was going to swap some files but maybe all hell will break loose.
see if I have time tomorrow to see where CEC input framework is kept.
thanks for the work Lewy will flash in the morning
Originally posted by clarkss12 View PostAfter a few hours of testing, Netflix will work, but have to side load it, also it still only plays in DVD quality. Kodi locks up whenever a video is selected to play, tried with the latest Kodi 15 and the latest SPMC, both have same problem of locking up, have to pull power on stick to reboot it.
So If you are a Kodi user you woudn't advice to install this ROM atm?
I'm using Kodi on the MK808b plus for all sorts of plugins and watching movies...
What functions are not working atm?
Originally posted by fbueller View PostWHY IS IT SO HARD TO ANSWER THIS QUESTION THAT'S BEEN POSTED NO LESS THAN FOUR TIMES IN THIS THREAD?
WILL IT WORK WITH THE AP6212 WiFi CHIPSET OR NOT?
Installed on my MK808B Plus...I was able to maneuver my way around installation by using a USB keyboard first for the home screen selections(Selected Wi-Fi first since my usb slot was taken by the USB keyboard). When setup was completed I was left with a black screen to which I then rebooted and was able to see home screen. Since I prefer ethernet connect and I found the Bluetooth screen and paired my Bluetooth keyboard freeing up the USB slot for a ethernet connection.
I am able to move around the screen using the USB mouse and Bluetooth keyboard keyboard. This UI was intended to be used with a remote. The Kodi used on rom is RC. I installed and attemped to playback a movie installed on my computer and got video but no sound. Then I changed audio setting on Kodi to "Enable passthrough" and was able to get sound
Better yet, install it on your device and let everyone know if it will work. Easy.
Not easy. Don't want to blow away my current installation to decide whether it works with a chipset when the developer can answer a simple question that many people are wondering.
There are currently 2303 users online. 3 members and 2300 guests.
