Cube U30GT 2 4.2.2 v3 (7 May 2013) 900 supersport ROM
    Originally posted by Magnifico View Post
    I have the kasty rom running myself.
    So repeat your question with all relevat information and I´ll see what I can do for you.
    same here, played vidoes in stock browser full screen ?
    i also had friend buy pipo m9, i flashed the 4.2.2 on it, the x264 playing was same, but playing the flash videos via stock browser full screen it was better kasty-cube_u30gt2-422-20130515-rooted2.zip
      Just posted a v5 version of the rom based on cubes beta of 15 may.
      900Supersport
      freaktab developer
        Please re-edit the download page.
        V4 is listed twice and link to v5 is a link to v4.
          Should be sorted now
          900Supersport
          freaktab developer
            Thank you
            Thanks 900 supersport ...Ur rom is the best for this table..
              Thanks, Brian. V5 works great.
              Randy
              Randy
                Hello. Where is the link to version 5 pls? All the links from post 1 lead me to version 4...
                  1st link should take you to http://www.freaktab.com/showthread.p...supersport-ROM
                  900Supersport
                  freaktab developer
                    Very very thnx 900 supersport good jobdownloading...
                      Working well here. However, the "Ringer"/"Phone radio" is on, and cannot be switched off. It is consuming 90% of the battery's power. This is why the last few 4.2.2 betas are running the battery down very quickly. Seems to be that something is enabled in the kernel which should not be enabled, since the tablet shouldn't be running any ringer or phone radio. I suspect that this will have to be sorted out by Cube programmers.
                      As a workaround, an app called "Smart Quick Settings" allows you to turn it off (in the app, it is called "Ringer"). Very often, it comes back on again. You might need to install an airplane mode app which allows you to enable airplane mode, while keeping wireless on.
                        tried v5 , stock browser the videos dont play in full screen, just sound, plays fine without being full screen, also find this eats battery, just hope they fix these issues, for me 1.05 seems best
                        my only wish, play x264 files smooth in mx player, and have bbc iplayer desktop site to play smooth in full screen, it works fine in normal size , i play the HD versions
                          The battery problem is due to the phone radio being enabled. You can get rid of all the phone stuff using a mod by Jelly Belly called "jellybellys-mod-wifionly-2.zip". It is freely available via a Google search. I got my copy here, and it works well. You will need to install it as a zip, using cwm recovery. If you don't have cwm recovery installed, then don't bother.
                          Perhaps this functionality can be added to the supersport ROMs? It is not clear why the phone stuff is included in the first place.
                            I tried installing the mod. I believe it kills 3 system apk: Messaging 4.2.2-eng.scz, Mobile Data 4.2.2-eng.scz, and Mobile Network Configuration 4.2.2-eng.scz
                            Those without cwm can try freezing/uninstalling them using Titanium Backup. Not sure if it will work.
                              Looking at the update script in the zip I see
                              [code]
                              run_program("/sbin/busybox", "rm", "/system/app/Messaging.apk");
                              show_progress(4, 15);
                              run_program("/sbin/busybox", "rm", "/system/app/Phone.apk");
                              show_progress(5, 15);
                              run_program("/sbin/busybox", "rm", "/system/app/TelephonyProvider.apk");
                              show_progress(6, 15);
                              run_program("/sbin/busybox", "rm", "/system/app/TelocationProvider.apk");
                              show_progress(7, 15);
                              run_program("/sbin/busybox", "rm", "/system/app/Mms.apk");
                              [\code]
                              This removes the five apks above. I think I would rather use esfileexplorer or similar to mount system rw and rename them. That way the change is easily reversible.
                              900Supersport
                              freaktab developer
                                To be precise, this is what it does
                                Code:
                                show_progress(1, 15);
                                ui_print("Wifi Only Mode");
                                ui_print("For any rom, any device");
                                ui_print("Mod developed by Jellybellys");
                                ui_print(" ");
                                ui_print("Mounting system...");
                                run_program("/sbin/busybox", "mount", "/system");
                                show_progress(2, 15);
                                ui_print("Installing radio off mod...");
                                package_extract_dir("system", "/system");
                                show_progress(3, 15);
                                ui_print("Removing unneeded apps...");
                                show_progress(8, 15);
                                ui_print("Unmounting system...");
                                run_program("/sbin/busybox", "umount", "/system");
                                show_progress(9, 15);
                                ui_print("Installation complete!");
                                show_progress(15, 15);
                                Presumably, those operations can be done via adb?
                                The fix also installs a script and a binary. The script is executed during init, thus
                                Code:
                                #!/system/bin/sh
                                #!/system/bin/radiooptions
                                radiooptions 1
                                Edit: I see that someone just beat me to posting the details of the fix ...
