Finless 1.7a installed and ran fine on my UG008 with the included kernel but had some issues with wifi, built-in ethernet, and the analog AV out. Replacing the kernel with the kernel from the original UG008 rom fixed the issues. This combination has proved to be very stable for me and I have only found 2 minor bugs. The first is that the menu bar popup displays 00:00:00:00:00:00 instead of the ssid of the wifi network you're connected to. The second is that attempting to turn on the wifi hotspot feature to broadcast an ethernet connection as wifi doesn't work. It just hangs while turning on and requires a reboot to get wifi back. Other than that, everything seems to be working 100%.
Prerequisites:
You must have CWM recovery installed on your UG008. I used the UG007 version of CWM. The installation guide and download link can be found here: http://www.freaktab.com/showthread.p...rk3066-devices
Installation:
Download finless17a_ug008_cwm.zip and move it to /mnt/sdcard or /mnt/external_sd.
Reboot into CWM recovery and make a backup of your current rom if you haven't already.
Wipe data, cache, and dalvik cache.
Install from sd or external sd depending on where you chose to place the file.
Enjoy.
If you like this rom, thank finless. He did all the real work. I just copied and pasted some files. If it wasn't for his time and effort making an excellent rom and Leolas' time and effort making the CWM .zip template and writing the guide to use it, this never would have happened.
